So a while after changing from my stock air cleaner to a new one, my temp gauge stopped working. I put in a new sensor today, still nothing. It does peak when I ground it using a test light though, as I have seen online.
I understand this could mean that it's not calibrated, is there a way to re-calibrate it? Any other troubleshooting I could do? I noticed one of my fuses is out, could that be the problem?
If it swings full scale when you ground and un-ground the wire, the gauge is good. Look at the connector or your new sender.
I'm not quite sure, it was the sender that the store I bought from recommended. I will admit it doesn't look exactly like the old sender I took out, I'll see if I can find a pic for it online.
By the connector, you are referring to the wire right?
