78 Tachometer issues
Old Apr 21, 2013 | 08:19 AM
Tbone39772's Avatar
Tbone39772
Navigator
Default 78 Tachometer issues
Just recently pulled my 78 out of storage and found that the tachometer doesn't work. The needle jumps slightly when I turn key on but other than that nothing. Do I need to put a tach circuit board in it? Any ideas?
Old Apr 21, 2013 | 08:42 AM
'75's Avatar
'75
Could be the brown tach wire is loose from the distributor or maybe the tach filter on the manifold is bad. You can bypass the tach filter and plug the wire directly into the dist to test it.
http://willcoxcorvette.com/advanced_...=tach&x=36&y=4
Old Apr 21, 2013 | 09:06 AM
mikes c3's Avatar
mikes c3
Default Tach
PM sent
To 78 Tachometer issues
