drive shaft angle
I have recently converted my ´73 coupe from automatic to manual.
To do so I have purchased kit from American Powertrain with Tremec T56 - 6 speed. I have put new transmission high in the tunnel as much as I could but still it is pointing down making my drive shaft angle too big. (Not to forget I had to modify trasmission cross member as well by letting transmission to sink down about 2 inch to be able to fit it in tunnel at all)
I did not measure current angle but it could be around 10 degrees or more. Of course I have vibrations while driving....
What would be a good way to deal with this problem?
Can I lower engine a bit down? I have new 2 piece motor mounts (CORVETTE Energy Suspension Motor Mounts/Motor Mount Inserts 3-1114R) with thick metal inserts. Can I take inserts out and just leave urethane mounts? Will my holes align?
I can still go up with transmission I might have 3/4 Inch tunnel clearance so far - so maybe I could take 1/2 inch.
Is there a way to lower differential? How much till I hit the frame? What is the best way to do it? Insert metal piece in between the diff. cross member and some shims in between bushings + larger nut?
I hope i will not have to cut the frame!!
Please help I would like to know all my options before I proceed
I had the engine 3 degrees down, diveshaft was flat at 0 degrees, and the diff was 0 degress. The original vette setup was almost flat, 0 degrees on all.
I couldnt drop the engine any lower, but was able to shim the trans mount up as high as possible.
The front of the differential is mounted to a "tongue" that bolts the the frame with a rubber isolator between. I cut the thickness of the rubber isolator down to move the pinion angle up. I've also seen other people redrill the "tongue" mount to increase the diff pinion angle.
I was able to get within 1/2 degree of the engine and diff matching, probably better than factory, no vibrations.
I have taken inserts out today from the engine mounts - it took me about 5 hours thanks to my headers :-)
Anyway I have managed to lower engine block by 1/2 inch, pretty good result. I hope to raise my transmission in couple of days also by 1/2 inch.
PS. You can turn off being able to see Related Threads..
