Side pipe sound when off throttle/decelerating
Old Apr 24, 2013 | 09:30 PM
jackwabbit703's Avatar
jackwabbit703
Default Side pipe sound when off throttle/decelerating
Anyone have side pipe sound that's like it's sucking air back in with loud burble? I mean sounds good to my ears but just wanted to know if anyone else has this sound effect coming from their side pipes.
Old Apr 24, 2013 | 10:04 PM
7t9l82's Avatar
7t9l82
carb may be lean. does it happen when you let off the gas at speed?
Old Apr 24, 2013 | 10:22 PM
jackwabbit703
Yup. Louder in 3rd gear and less louder in 4th. Checked plugs and they are tanish brown. Re adjusted mixture after adjusting timing last week. But this sound existed way before adjustment of mixture last week. It's less louder than it used to be after advancing base timing tho. By all means, it's not popping or snorting. Sound actually is very nice to my ear.
Old Apr 24, 2013 | 10:54 PM
Peterbuilt's Avatar
Peterbuilt
Default Same with my chambered exhaust.
I have the same burble when I let off the gas at highway speed.
Old Apr 25, 2013 | 08:51 AM
Belgian1979vette's Avatar
Belgian1979vette
When you close the throttle at speed, the engine creates a lot of vacuum in the intake tract and at the same time exhaust pressure is a lot lower. Therefor it will suck the exhaust into the intake during overlap. The amount of reversion (burble you hear) will increase as the amount of overlap is increased.
Old Apr 25, 2013 | 09:39 AM
jackwabbit703
Thank you for very intuitive and descriptive information. So, sound I'm hearing is "normal?"
Old Apr 25, 2013 | 09:48 AM
Belgian1979vette
Yes
Old Apr 25, 2013 | 10:28 AM
nodebtvette's Avatar
nodebtvette
I just got the 76 out for the first time with the side pipes and have the burble as well.
Never really thought about it until I saw this post. Thanks for the info.
Old Apr 26, 2013 | 08:35 PM
worship79's Avatar
worship79
I like the sound, especially in tunnels
Old Apr 26, 2013 | 11:39 PM
jackwabbit703
Originally Posted by worship79
i like the sound, especially in tunnels :d
amen!
Old Apr 27, 2013 | 08:38 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
IMHO, a lot of what the sidepipes sound like, is determined by the compression ratio of the engine. The early, high compression cars, have a sharper bite to their sound. The later, low compression cars, have more of a "motorboat burble" sound.
Although I didn't personally have the sidemount headers on a Corvette, I had them on a '77 Trans/Am I used to own. The T/A had a 400 cu.in. Pontiac engine, but a low compression version. At one point, I took it "around the block" with open headers, and it sounded pathetic...LOUD, to be sure, but pathetic.....
Old Apr 29, 2013 | 05:08 AM
worship79's Avatar
worship79
1:10.3 compression with a 383 stroker and a Comps XE274H cam, no worries on the sound
To Side pipe sound when off throttle/decelerating
