I wonder
Old Apr 27, 2013 | 11:20 AM
7T1vette's Avatar
7T1vette
750 cfm will be more than enough for a stock L-48 with a small blower. No need to swap out the Q-Jet, if you can connect everything with no problem. The Q-Jet will provide better economy and transition from idle to cruise to WOT than the Holley...but either would work OK.
Old Apr 27, 2013 | 11:24 AM
SuperBuickGuy's Avatar
SuperBuickGuy
despite what it seems, I like quadrajets - but I'd verify that you can run a quadrajet on the blower without a spacer... I think I tried to run one on mine, and had interference with the secondaries hitting the blower case... no big deal if you run a spacer, but on a C3 a spacer may force a lot more body work in the form of a hood scoop
