My 1978 died.. Help!!!
Old Apr 26, 2013 | 08:43 PM
tjlawson1's Avatar
tjlawson1
Default My 1978 died.. Help!!!
Here is the quick story, I was driving my car and all of a sudden everything shutdown, so i coasted to the side of the road and when i tried to start it absolutly nothing happened. i couldnt hear any noises after turning the key, and a jump start did not work. battery is pushing 600 amps. I'm not very mechanically inclined so I thought I would ask for ideas on what it could be. Thanks for the help!
Old Apr 26, 2013 | 08:58 PM
birdsmith's Avatar
birdsmith
Bad ground somewhere/ burned fusible link? Do you have any electrics at all? Lights, anything? If there's nothing that's the first place I'd look. The fusible links come off of the starter solenoid- look down there for anything that looks like burned wires...
Old Apr 26, 2013 | 10:19 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Get a voltmeter and a wiring diagram and start with the battery and work your way out. Good luck!
Old Apr 27, 2013 | 01:18 AM
bluedawg's Avatar
bluedawg
I agree with birdy. Bad ground.
Old Apr 27, 2013 | 03:07 AM
tjlawson1's Avatar
tjlawson1
The only electrics that work are the head and tail lights... All other electrics are down. I will check out the selenoid and look for bad wires!
Old Apr 27, 2013 | 04:51 AM
hunt4cleanair's Avatar
hunt4cleanair
Originally Posted by birdsmith
Bad ground somewhere/ burned fusible link? ...
My first thought as well. I had trouble with my 78 on the starter ground strap. When I found it, it was hanging on my strands of copper and was corroded and gunked up.
The starter ground strap bolts to the starter support bracket that supports the starter nose to the engine. the other end bolts to the frame.
Old Apr 27, 2013 | 07:29 AM
Indiancreek's Avatar
Indiancreek
Being an optimist, she's not dead, just passed out and needing a little CPR!!!!!!
Old Apr 27, 2013 | 08:55 AM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
As mentioned above, get your voltmeter and start at the battery. See how many volts your battery is putting out. If it is below 11.5 or 11V, I would first charge the battery and make sure you have a full charge. Besides checking your grounds, get your alternator checked to see if it is working correctly. I also had the same problem you did with my 82, it shut down completely doing 65 mph, was fortunate to get over to the side of the highway safely, and did not have anything at all, not even lights. everything shut down and had to get it flatbedded home. It ended up being a combination of the wiper control module and the alternator both being faulty, which in turn drained my battery completely. Had the wiper module rebuilt with modern day electronics and replaced the alternator, and it has been fine since.
Just some more suggestions for you, hope you find the problem...Tom
Old Apr 27, 2013 | 09:57 AM
scottw's Avatar
scottw
Start at battery and work your way down. Last weekend, I pulled in the garage, turned off and went to restart and nothing at all. Did the same thing. Started at the battery and worked way down. Ended up being the S wire to the battery had broke at the connector. Re-hooked it up and no issues.
So, you have head and tail lights but nothing inside the car? No light, radio, dash lights? Are the headlights bright or very dim?
Old Apr 27, 2013 | 10:08 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
There is one fusible link for the lights and 1 for the fuse box.
Old Apr 27, 2013 | 11:19 AM
SuperBuickGuy's Avatar
SuperBuickGuy
Fuseable link is burned.... very, very common.
look for two cylinders in the two power wires that are attached to the front of the starter (the battery cable is attached, and those two wires).... it sounds like you burned one of those wires, or the fuse in one of those wires blew.
Good news is it's not too hard to fix
bad news is you need to find the short that caused it
I had a similar thing happen to me.... on a very dark road at 5 am... I was going 60 mph, then suddenly I was driving in the dark, with just tire noise. I got both of those wires up against the header.
Old Apr 27, 2013 | 01:10 PM
tjlawson1's Avatar
tjlawson1
I looked at the starter and everything looks good, I did however find a ground wire the has been disconnected from somewhere, one end is attached the the passenger side cylinder head on the firewall side. Anyone know where it should go?
Old Apr 27, 2013 | 02:51 PM
74 LS4-454's Avatar
74 LS4-454
the one that I have on the 82 goes from a wing nut on the firewall on the RS to the lower left bolt on the passenger side valve cover.
I don't think that would be your problem. As mentioned in previous posts, you either have a fusible link gone bad somewhere, or there is something else shorting your system out.
Again, start from the beginning (your battery) and work from there. Check your HEI system, you may have a wire loose under the cap, or your ignition module may be fried, and once they go, you don't go.
Take your module out, make sure there is either silicone lube or thermal compound between the bottom of the module and the plate it attaches to, a thin even coat will do fine. See if the module looks burnt from underneath, if you can't make that determination, take it to one of the "parts" stores, and they can check it for you....
and make sure you check the cap, rotor and coil....etc., etc.....
Old Apr 27, 2013 | 03:44 PM
tjlawson1's Avatar
tjlawson1
Where can I find the fusible link? I know what it looks like I just am not sure where to look.. Thanks for all the help!
Old Apr 27, 2013 | 04:42 PM
SuperBuickGuy
it connects to the starter solenoid, it's the top, smaller cylinder in this photo. On the right side of the photo are 3 lugs, 2 smalls ones, and one large one - the large one is where the battery cable, and the power feed lines are for the car
The fuseable links are the larger cylinders, and are part of the wire (they're not serviceable, but have to be replaced by chopping out and soldering in new links (there are other ways, but for clarity focus on this)
they look like this
Old Apr 27, 2013 | 04:55 PM
Indiancreek
On my 71 there was one inside the drivers side front fender tucked up under the lip. When it went everything stopped.
Old Apr 27, 2013 | 05:04 PM
BKarol's Avatar
BKarol
From Tom Russo's 78 pics:
To My 1978 died.. Help!!!
Old Apr 27, 2013 | 05:11 PM
tjlawson1's Avatar
tjlawson1
Found it!!!! Thanks a lot! I will replace them and see if that works! I can't wait to ride again
Old Apr 27, 2013 | 11:58 PM
tjlawson1's Avatar
tjlawson1
It was the fusible links! Car runs great! Thanks everyone!
Old Apr 28, 2013 | 12:44 AM
SuperBuickGuy
good job - there's nothing like your first, successful fix... bask in the glow, you deserve it
