Control Arm cross shaft play?
Old Apr 30, 2013 | 08:32 PM
MacVette86's Avatar
MacVette86
Default Control Arm cross shaft play?
In a previous thread, I decided that pressing in my new poly control arm bushings was too hard for me, so I took them to my local Corvette dealer to have them done. I got them back today and noticed that the cross shafts in the lower control arms have quite a bit of lateral movement between the bushings. The shaft will move about a quarter of an inch side to side. Is this normal? The upper control arm shafts have almost no play side to side.
Old Apr 30, 2013 | 11:55 PM
wombvette's Avatar
wombvette
First thing you did wrong was use poly, the second was take them to a Chevy dealer.
No there should be no play. Did they tighten the end bolts?
Old May 1, 2013 | 12:00 PM
MacVette86's Avatar
MacVette86
I posted this question without thinking it through first. You are correct that I did not have the shat bolts in place and tightened, so that's why I have the play.
As for using the poly bushings, I actually had both poly and rubber bushings from a couple of different front end kits I ordered. I asked VBP, VanSteel and my local Corvette shop that's been in business for over 30 years and they all said go with the poly bushings for the front end.
Old May 1, 2013 | 01:05 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Poly is good for certain applications and every ones application is different.
The poly bushings you have, do they have a gold shell or black shell? Did they put the inner sleeve in the bushings?
Old May 1, 2013 | 02:29 PM
MacVette86's Avatar
MacVette86
I have the black shells and yes they put the inner sleeve in the bushing.
Old May 1, 2013 | 02:37 PM
wombvette's Avatar
wombvette
Make sure you use lock tite or you will be picking up bolts and washers from the road.
Old May 1, 2013 | 06:38 PM
MacVette86's Avatar
MacVette86
Thanks wombvette, I had read about the shaft bolts loosening with the poly bushings, so I'll be sure to use the locktite
Old May 1, 2013 | 07:00 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
When I rebuilt the front end on the '79 that my wife used to own, I went with poly bushings, because we were using the OE sized, 225/70/15 tires. They have PLENTY of sidewall height, to provide a nice, cushy ride.
Old May 2, 2013 | 03:26 AM
Dirk76's Avatar
Dirk76
when is poly not recomended for front end.
Old May 2, 2013 | 06:42 AM
7T1vette's Avatar
7T1vette
When the car was originally built....
To Control Arm cross shaft play?
