Shifter rebuild
Paragon Corvette has a really nice shifter rebuild kit and everything was exactly like the factory set up.
It seems overkill to get the whole kit. There is nothing wrong with the **** or reverse handle for instance.
The only kit I saw on Paragon was the linage kit but the linkage appears fine.
Muncie M-21
https://www.paragoncorvette.com/p-35...it-muncie.aspx
Borg Warner Super T-10
https://www.paragoncorvette.com/p-34...rg-warner.aspx
Also, you will need to adjust the linkage and you need to tell us what year Corvette you have, so we know what tranny you have in the car. Finally, do you have the AIM or Assembly Manual for your 'Vette? Do you have the FSM or Factory Service Manual for your car too?
I ask this, because adjusting the four speed transmission in your Corvette is no easy task. You have to have all the bolts on the rods loose enough to allow front to back motion and then have the transmission in neutral [not the shifter, but the actual transmission itself] for each set of inputs (1-2, 3-4 and Reverse).
I have a late 1974, with the Borg Warner Super T-10 and I had to make a 0.644 gauge to set up and lock into place neutral in all three actuators (look at the picture you provided and you'll see a perfect square on the bottom of each, the gauge is pushed in from the side to lock 1-2, then keep pushing in to lock 3-4 and finally, have somebody push the shifter into reverse against the stop and you'll get the reverse neutral too).
Then you adjust the bolts on the rods, one by one to lock the rods, front and back into the neutral position for each set of transmission inputs and you're done. Don't forget to lubricate generously.
Again, this isn't easy. The room that you have to work with, is very, very limited, because all of this, is in the transmission tunnel, alongside the transmission.
Those two spacer pieces are the important part. One is wide, one is narrow. Only way to know which one to use in my experience is to take apart the shift mechanism and fit it.
That new pin is nice to replace also.
I will say that taking out the shift Mechanism on my 81 is a huge PITA.
I will try and post some pictures later.
There are those, who don't want to cut holes in their Corvettes, but back in the day, the body was dropped on top of the chassis, with the engine and trans, already in place. I got tired of playing painful hand origami and spending hours and hours underneath the car, just trying to tighten one %#%$# bolt and barely able to do it. Your call.
My gauge that goes in from the top.
I did it the hard way, from the bottom. It is almost impossible to get the little set tool in place.
Even though I have a piece the right size, I could never get it in place with my huge hands. My wife wouldn't let my grand daughter under the car to help.
So, I put her in the drivers seat to hold the shifter in place and after what seemed like a million times of tinkering I finally got it right.
I'm not totally sure about other years, but on my 81, the cross member is bolted in place and can be lowered with the shift mechanism attached.
I am not sure what people are referring to when they say you can just squeeze the U where the shifter sits together. If it has bent apart you probably have some other problem. There is a large through bolt holding it to the upright. If that U is bent, it would have taken an awful lot of force to do it.
You have to make sure to disconnect the linkage and support the transmission with a jack.
That crossmember is not easy to remove. There are two bolts and a large pass through bolt on either end. Over the years, the twisting and turning of the frame has sort of fitted these parts together.
Also, the transmission is bolted to it.
As silly as this may sound, don't forget to remove the shifter ball and reverse handle. It all comes out as one unit.
On the 81, the shift mechanism is bolted to the cross member. I understand this is not the case on all years, and some are welded.
I believe that all the four speed shift mechanisms are the same. Only the linkage varies depending on transmission.
