should I remove my hood?
Old May 1, 2013 | 09:36 PM
WHITE 1974's Avatar
WHITE 1974
Default should I remove my hood?
Anybody who has replaced there radiator and rad cradle remove there hood, or do you think i can get them in and out with the hood on any advise would be appreciated
Old May 1, 2013 | 09:46 PM
bluedawg's Avatar
bluedawg
I've not done the core support but either way it would be easier with the hood off. Mark the hood were the hinge plate contacts the hood in order to reinstall with out issue.
Old May 1, 2013 | 09:56 PM
gcusmano74's Avatar
gcusmano74
R & Ring the radiator on a 74 C3 is a huge PITA. Generally, the hood comes off first. It's not all that heavy, just awkward to handle. Don't forget to unhook the cowl induction solonoid wiring. Get a buddy to help.
The hard part is that the upper control arms will capture the shroud. Either you need to remove the upper bolts on the radiator support and swivel it forward (the air conditioning condenser will complicate this) to allow enough clearance to remove the radiator. .
Or you remove the forward upper control arm bolts. They are pressed in place. The shoulders of the bolts are knurled to retain them in the frame. You have to tap or push them straight into the spring towers to remove the bolts. Obviously, you must support the lower control arms when you do that.
Old May 1, 2013 | 10:41 PM
rafalc's Avatar
rafalc
I just did this couple months ago. ABSOLUTELY remove it
Old May 1, 2013 | 10:47 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
It's really a 2 man job but needs to come off to do the job.
Old May 2, 2013 | 02:31 AM
Tim H's Avatar
Tim H
I never removed my hood on the 76.
I replaced the radiator but did not put back a shroud.
Old May 2, 2013 | 05:51 AM
Haggisbash's Avatar
Haggisbash
The whole job is far easier with the hood removed. I removed the hood, then the fan from the water pump, loosened all of the rad support bolts and then removed all but the two lower side bolts, this allows the support to be tilted forward which makes it easier to remove the fan shroud. You need to remove the trans oil cooler (if one is fitted) from the front of the radiator which can then be lifted clear ( some fit the core with cardboard covers to prevent damaging it). Now the radiator support can be removed. You may find it easier to put the car on jack stands at the front (not under the middle of the cross member though) and remove the front wheels which allows much easier access to the core support bolts. All this worked for me, others might have a different technique!
Old May 2, 2013 | 08:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by WHITE 1974
...do you think i can get them in and out with the hood on...
Why even try? You'll just be muttering under your breath. Scribe around the hinges on the hood, remove the bolts, unbolt the hood support, and lift the hood off.
Old May 2, 2013 | 09:00 AM
MrJlr's Avatar
MrJlr
Been there, done that, got a T-shirt.
Remove the hood.
Old May 2, 2013 | 09:09 AM
sstopczy's Avatar
sstopczy
On my '79 I removed the shroud and radiator and replaced the radiator with the hood on. I did the job by myself. If you just take your time it can be done. I didn't remove the support, but I am thinking once the shroud and radiator are out it shouldn't be too hard.
Old May 2, 2013 | 03:15 PM
spinadog's Avatar
spinadog
As Easymike mentioned, scribe around the hinges and get 'er off. you'll have little issues realigning it back - must have removed my hood six times by now.
Old May 2, 2013 | 05:25 PM
mds3013's Avatar
mds3013
One more tip. Use blue painters tape and place a couple of layers around the sides of the hood and hood surround to prevent nicks and scratches when you take it off and re-install. mike...
To should I remove my hood?
