How often do you drain your compressor?
Old Jun 21, 2002 | 02:19 PM
mayberg's Avatar
mayberg
Default How often do you drain your compressor?
Maybe I should make it a poll, but how often should I drain my 25 gallon 2-stage 120V 175psi compressor?
After each use?
When I feel like it?
After x number of charge cycles?
Once a year?
Letm me know your thoughts. GM
Old Jun 21, 2002 | 02:22 PM
MikeC's Avatar
MikeC
Default Re: How often do you drain your compressor? (mayberg)
Depends how humid your air is, how hard you use your compressor. I usually drain mine the day after I have run it hard. The longer you wait, the less capacity your compressor will have and the more rust that will form in the tank.
Old Jun 21, 2002 | 03:16 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
My manual says daily :rolleyes: but realisticly I agree with it depends on how hard it's been used, weather etc...
Old Jun 21, 2002 | 03:31 PM
MIKER's Avatar
MIKER
Uh. . . If I tell, do you promise not to turn me in to the "Compressor Protective Services Agency" for neglect? :( :D
I have a Black Max 5 hp, twin cylinder w/60 gallon tank. I've had it for about 7 years. I used to drain it on a regular basis but I must admit, it has been over a year since I last drained it. I need to replace the drain valve on the bottom because the little ears used to turn it with have sheared off.
I certainly think that it is best to drain it on a fairly regular interval dependant on use but consider this question. . . Will the tank rust any faster with a puddle of water in the bottom than it will with a constant layer of moisture covering the tank internals? Are there ever ANY dry spots on the inside of an air compressor tank? :confused:
[Modified by MIKER, 1:31 PM 6/21/2002]
Old Jun 21, 2002 | 03:36 PM
Chuck Harmon's Avatar
Chuck Harmon
A fair amount of water builds up in there pretty quickly. Whether it is a few ounces or a quart, the rusting will damage the lowest part of the tank just the same and ruin it. I installed a 90 degree elbow at the bottom of my tank and attached a short length of clear high pressure tubing to it with a simple twist valve at the end. I can see the water that collects in this line and know that it is time to open the valve and drain it out.
The first several times I drained it the water was rusty. Now when I do it, it is clear. The water collects first in the plastic tube, not in the tank.
Chuck
Old Jun 21, 2002 | 03:45 PM
MIKER's Avatar
MIKER
Default Re: How often do you drain your compressor? (Chuck Harmon)
Good tip Chuck! Since I have to replace my drain valve anyway, I'm going to use a setup like yours. :cheers:
Old Jun 21, 2002 | 04:18 PM
Gordonm's Avatar
Gordonm
Default Re: How often do you drain your compressor? (MIKER)
Uh Not often enough. Probably a couple times a year. Mine does not get regular hard use but it still should be drained. Think I'll go drain it now
Old Jun 21, 2002 | 11:46 PM
VetteNut72's Avatar
VetteNut72
Good idea Chuck!!
I'm just afraid mine would dry out and crack off before I ever saw any water in it! :D
I have had my 60gal vertical for about 6 months and have never found water in it. Could have something to do with where I live. Check out my sig for current time/temp. In the heat of summer, it might cool down to 95 at night. I don't even want to think about how hot the garage gets.
Now there are some areas of the country where you guys probably have to drain after each use.
[Modified by VetteNut72, 8:48 PM 6/21/2002]
Old Jun 22, 2002 | 01:02 AM
noskillz's Avatar
noskillz
weekly, get nearly a pint too
Old Jun 22, 2002 | 01:40 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: How often do you drain your compressor? (noskillz)
I don't use mine that often but when I'm finished I drain it
Old Jun 22, 2002 | 10:35 AM
Tominator's Avatar
Tominator
Every time there always a water build up in mine, I just consider it's part of putting it away. Usually open it and then roll up the hoses, when the hoses are done the tank is drained.
Old Jun 22, 2002 | 10:46 AM
Matt Gruber's Avatar
Matt Gruber
chuck
Great idea! where can i buy clear high pressure tubing?
Anyway, 12 years ago i installed an automatic drain plug, cost $10. When the pressure drops below 10psi it pops open by itself. Whenever i forget to turn off the main valve, overnight it drains itself!... and resets when i turn it back on :cool:
Old Jun 22, 2002 | 10:49 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: How often do you drain your compressor? (drives61)
I guess I don't do mine often enough. I'm off to do it right now!
Old Jun 22, 2002 | 12:32 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: How often do you drain your compressor? (VetteNut72)
Moisture ....... In the air ???
How the hell does that happen ?? I have never heard of air being "wet"
Chandler Arizona resident ----
To How often do you drain your compressor?
