on our 72, when the running lights are on, both tail lights work just fine but when the brake pedal is pressed, only the left side brake light comes on and the right side goes out completely. Also, when the running lights are not on, the right side brake light does work but is dimmer than the other.
i have a wire diagram, but some of the wire colors have been changed from factory or painted over, making it hard to distinguish between colors.
make sure the correct bulb is in there as well. Bubba did a repaint on mine and every single bulb in the car was wrong. I spent about $50 at the store buying just bulbs. all work nicely now though except REV which I need to crawl under and fix the switch.
Should be a 1157 bulb back there. Chances are the bulb is installed incorrectly.
The pins on the side of the bulb are offset but that doesn't mean they cant be installed wrong
Check your grounds. I have also replaced most of the sockets for the bulbs over the years. The contacts corrode with time and it seems that no amount of cleaning will make them work reliably.
