Horsepower rating
Old May 3, 2013 | 12:22 PM
tpoulson's Avatar
tpoulson
Default Horsepower rating
I just took my value covers off for the first time. I discovered head numbers 3917291 and solid lifters. Specs show this could be either 300hp OR 350 hp. What do I have?
Old May 3, 2013 | 01:18 PM
birdsmith's Avatar
birdsmith
How could you tell it had solid lifters just by pulling a val(v)e cover? The solid-lifter LT1 from 1970 was rated at 375 hp, and it dropped year-to-year after that as compression ratios were lowered...
Old May 3, 2013 | 05:23 PM
Alan 71's Avatar
Alan 71
Hi tp,
The info I have indicates the heads with that casting number were used on 327ci 300 and 350 horsepower engines in 1968.
I believe both those engine's configurations used hydraulic lifters.
Regards,
Alan
Old May 3, 2013 | 05:36 PM
Brcmpbl's Avatar
Brcmpbl
tp, if you do in fact have solids they would be someone's addition. There was no solid lifter small block in 1968...just two 427s, the L-71 and the L-88, had solids. The 1970-1972 LT-1 350 small block had solids and ratings of 370 (70, gross), 330 (71, gross), and 255 hp (72, net).
Old May 3, 2013 | 08:18 PM
Big Block Dave's Avatar
Big Block Dave
I suppose if he checked the lash and found each valve had + - .020 lash, then you could make the determination that it was a solid cam, or a hydraulic out of adjustment
Old May 4, 2013 | 06:07 PM
tpoulson's Avatar
tpoulson
Yep, while we we're adjusting the valve lash we discovered they were solid lifters. Thanks for asnwering our question. Must have been the original owner.
To Horsepower rating
