Rear Center Tail Light Problem
Old May 3, 2013 | 08:03 PM
rodney25's Avatar
rodney25
Default Rear Center Tail Light Problem
Hi All,
Was wondering if anyone can help in final stages of a 1975 convert able restore. Replaced all the lights front and rear and all work fine except the center rear tail lights, the tail lights with the red and clear lens. Neither one will light. The outer are fine. Does anyone know what would cause them not to work and any way to test or troubleshoot the problem? Any help is greatly appreciated.
Thanks.
Old May 3, 2013 | 08:26 PM
mrmagrath's Avatar
mrmagrath
Your reversing lights? Did you put the car in reverse to see if they lit up?
Old May 3, 2013 | 09:10 PM
rodney25's Avatar
rodney25
Yes, it's a 4speed. Iput in revers and nothing, both lights don't light. I replased the light but sgill nothing.
Old May 3, 2013 | 09:28 PM
Alan 71's Avatar
Alan 71
Hi Rod,
Have you checked the back-up light switch that's mounted on the transmission?
The reverse lever on the trans moves a little rod which moves a small lever on the switch.
The wire from the switch runs forward and joins a lead that disappears through the firewall.
Maybe?
Regards,
Alan
The pink 'glob' is insulation on the switch's body. You can just see the small rod between the two large shifter rods.
Old May 3, 2013 | 10:19 PM
rodney25's Avatar
rodney25
Wow thanks. No I didn't check under the car. I was thinking it could be a fuse or bulb or wire.
Thanks.
Old May 5, 2013 | 09:30 AM
rodney25's Avatar
rodney25
Thanks.
OK found the issue thanks to all of you. Broken wire from the switch, all light work fine.
Thank you all again.
To Rear Center Tail Light Problem
