Rear suspention clunk after breaking
Old May 5, 2013 | 07:33 AM
badass37's Avatar
badass37
Default Rear suspention clunk after breaking
My 72 has developed a clunk in the rear suspension when I release the break and apply the throttle. It hard to describe but it is 1 solid clunk and a slight side to side shift, after making a complete stop. The movement I feel concerns me the most.
I have some other responsibilities this morning, but I am hope to get under it tonight. I am just looking to be pointed in the right direction.
Thank You,
Old May 5, 2013 | 08:18 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Check the front forward bushings on the rear control arms. If they go bad, they will allow the control arms to move side-to-side changing your rear wheel's toe-in. This will make the car shift sideways under acceleration. Been there myself years ago.
Another source of the clunking could be a loose forward differential mount. If the bolts loosen up a bit, the forward mount underneath the driveshaft u-joint will shift slightly up & down, but makes a nice clunking sound.
Good luck
