73 L48 piston swap
Old May 5, 2013 | 08:36 AM
4 speed's Avatar
4 speed
Default 73 L48 piston swap
I have a 73 L48 4 speed car, the L48 being an 8.5 to 1 compression ratio, Iam sure it has dished pistons. I have a set of stock bore 350 flat top pistons. any Idea what the compression would raise to ?
Old May 5, 2013 | 12:43 PM
7T1vette's Avatar
7T1vette
Somewhere around 9.0, I think. You should still be able to run on "mid" grade of fuel without pinging. If you have the engine torn down, are you considering any other modifications while you are at it? Better cam and aluminum heads [to match with cam] would be best, if you can afford it.
Old May 5, 2013 | 01:28 PM
scottyp99's Avatar
scottyp99
I don't know if I'd bother putting new pistons and rings in without boring it, to get the bores perfectly round again, in which case, your stock bore size pistons won't do you much good obviously. But, for all I know, your stock bore may be in good enough shape for such a swap, might just need a dingle ball hone, so that's up to you.
If your current shortblock has decent compression, an easier (probably more expensive, though) way to increase compression would be to use a thinner head gasket, and some heads with a smaller combustion chamber. You can get pistons pretty cheap, though.
http://www.northernautoparts.com/Pro...uctModelId=380
Scott
Old May 5, 2013 | 01:36 PM
4 speed's Avatar
4 speed
no just thinking about this coming winter, have this piston and rebuilt rods, car is numbers matching still so I'd like to keep it stock looking.and keep the block stock.
just a clean up and bearing job.
kinda thought that would be a bit higher closer to 10 to 1.
if I decide to go modified I have a 454
Old May 5, 2013 | 02:23 PM
7T1vette's Avatar
7T1vette
L-48 has 76cc heads; dished portion of piston is 5-7cc. So, it would be a 7-8% increase in C.R. Not that much gain for a lot of work. I sure wouldn't tear an engine down just for that change. But, if you changed heads, cam, headers, the gains would be significant.
Old May 5, 2013 | 02:38 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Surely can't hurt...but nothing dramatic. I remember back in the 70's/80's I installed quite a few 11.0 domed pistons in these engines for folks who wanted to keep the old heads. Got you into the 10'ish range and worked OK. There weren't as many good heads available back then of course. Today,,,swapping heads would be a lot easier and yield much better results.
As mentioned, if you want to do it right...boring the engine and getting cylinders perfect is important. Cast flat top pistons are cheap...so doing it right won't cost too much. If wanting to go mega cheap and you have the pistons...throw a quicky hone on it and drop them in and keep your fingers crossed.
JIM
Old May 5, 2013 | 02:59 PM
7T1vette's Avatar
7T1vette
If you don't bore the cylinders out, you can install new pistons & rings, then keep fingers crossed. But, don't be surprised if the rings won't seal...
Old May 5, 2013 | 03:15 PM
7t9l82's Avatar
7t9l82
not very much benefit for the effort. small chamber heads and a cam are a better route, if you want it to look stock you can paint the aluminum heads.
Old May 5, 2013 | 05:25 PM
REELAV8R's Avatar
REELAV8R
7T1vette L-48 has 76cc heads; dished portion of piston is 5-7cc. So, it would be a 7-8% increase in C.R. Not that much gain for a lot of work. I sure wouldn't tear an engine down just for that change. But, if you changed heads, cam, headers, the gains would be significant.
The l-48 has 17cc pistons. The best you could acheive with 58 cc heads and .015 gasket Using stock heads that are in reality 79-80cc heads and the stock cam is about 8.0:1 if you figure the stock cam at a 260 duration.
I've cc'd both the pistons and heads on a stock l-48. You'll be better off changing heads and pistons to get any kind of compression.
Old May 5, 2013 | 11:54 PM
thiatt's Avatar
thiatt
I agree it'll still be a dog with the stock heads and cam. The stock stuff falls out real early in low 4000 rpm range. You'll hardly notice the difference. Not worth the effort.
Old May 6, 2013 | 01:37 AM
mrmagrath's Avatar
mrmagrath
Just rebuilt my L48 with flat top pistons. I'd be a bit dubious fitting new rings in a worn bore. And I'd definitely get the rotating assembly balanced! My 2c!
Old May 6, 2013 | 08:38 AM
4 speed's Avatar
4 speed
think Ill look into just building another block, and just stick this one under the bench, it undoc 56k,
or just go for the BB 454!
To 73 L48 piston swap
