1972 Differential Rebuild Question
Old May 7, 2013 | 03:00 PM
Miccar's Avatar
Miccar
Default 1972 Differential Rebuild Question
I am going to have my rear differential rebuilt in a few weeks. Is there anything else I should consider replacing while this is being done?
Old May 7, 2013 | 03:09 PM
zwede's Avatar
zwede
U-joints, bushings, shocks are things I would take a look at.
Old May 7, 2013 | 03:59 PM
Miccar's Avatar
Miccar
Default Shocks, U-Joints & Bushings
Which bushings should I inspect for?
Old May 7, 2013 | 04:05 PM
rafalc's Avatar
rafalc
strut rods and/or bushings? body-off resto? just kidding
Old May 7, 2013 | 04:17 PM
zwede's Avatar
zwede
You should be able to check all of them. With the diff & spring removed you can pull/twist the trailing arms and check the front T/A bushings. Strut rod bushings are right there, same for the diff front mount bushing.
Old May 7, 2013 | 04:46 PM
Schaggy's Avatar
Schaggy
This is the PERFECT time for all that 'while you're in there' stuff.... Like a carbon fiber leaf, rear wheel bearings (and trailing arms), shocks, rebuilt driveshafts and propeller.... Heck, 'while you're in there', how about the trans? You might as well pull that and what about the clutch? Main seal.....GAH!
It's a DISEASE man! - Just keep diggin' 'till you run out of money!
To 1972 Differential Rebuild Question
