Idle problem with AC on
I got everything working except the Solenoid fast throttler so the engine does not choke with the AC on when idling. I am having a number of issues getting this worked out and I was hoping you fellows could help me out
1) I got a 80457-8 Holley carb. Which is a problem because it doesn't show up anywhere on their site. so I can;t figure out if this is really the model number. After a few hours online I found someone saying It is the aluminum version of the 80457SA. But I am not sure of this. :/
2) Holley only sells 1 solenoid fast idle that only works with 2 out of the multitude of brackets they have.
https://www.holley.com/46-74.asp Solenoid
http://www.holley.com/20-47.asp
http://www.holley.com/20-58.asp
http://www.holley.com/20-72.asp
http://www.holley.com/20-9.asp
Thanks ahead Guys.
carb pictures
http://www.holley.com/data/Products/...0installed.pdf
