Timing Chain Replacement
Old May 10, 2013 | 02:50 PM
Jack Sorenson's Avatar
Jack Sorenson
Default Timing Chain Replacement
I have read many threads on replacements so far, here is my question. Does the radiator need to be removed? I just last year had it out for AC repair - what a pain! Any tips other that Water pump replacement?
Old May 10, 2013 | 03:21 PM
MelWff's Avatar
MelWff
No the radiator does not have to come out and buy a good quality double roller chain and gears.
Old May 10, 2013 | 03:45 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Agree..
Old May 10, 2013 | 04:20 PM
BOOT77's Avatar
BOOT77
I went with a cloyes single true roller to avoid block issues some blocks/double rollers have. The single roller chain compared to a cloyes double roller was a tad heavier, because the rollers are larger I can't see why it wouldn't be as good as a double. I think it was lil over $30 and for newer roller motors, but no issues so far.
Old May 10, 2013 | 07:51 PM
jb78L-82's Avatar
jb78L-82
No the radiator does not Have to come out. Just changed my OEM timing chain and gears to a comp cams adjustable double roller chain and advanced the L-82 cam 4 degrees to shift the power band down the rev range slightly and that is exactly what the kit did. Peak 280 RWTQ at 4,000 RPM to 3,500 RPM on the dyno.
Old May 10, 2013 | 10:41 PM
bluedawg's Avatar
bluedawg
I agree the radiator and and shroud canstay, and definately go double roller. You can get ones from cheap to expensive, unless you plan on running up past 6500 rpm, go middle of the road on price.
Old May 12, 2013 | 05:33 AM
terrys6t8roadster's Avatar
terrys6t8roadster
To Timing Chain Replacement
