Need second opinion - carb and intake
Old May 11, 2013 | 06:31 AM
sassidan's Avatar
sassidan
6th Gear
Default Need second opinion - carb and intake
Hi,
New to the forum and Vettes in general.
Just purchased a 76 L82, and having some problems with the driving.
The driving is not smooth, especially in low speed. It also smells like a gas station.
The mechanic said that the main problem is the carburetor and he recommended to:
1. Replace to Holley, and not to rebuild the Rochester.
2. Replace the intake to aluminum, since after we install the Holley adaptor, the air cleaner won’t fit under the hood.
Questions:
1. Holley or Edelbrock carb? Which model then?
2. Do I really need to replace the intake? Other than the weight, Will aluminum intake make any improvements?
3. If I keep the stock intake but change the air cleaner to a slim filter, will it fit? which cleaner then?
Thanks!
Old May 11, 2013 | 06:56 AM
BKbroiler's Avatar
BKbroiler
Holley makes a carb that is a direct replacement for your Rochester Quadrajet. It is a spread bore unit which does not require an adapter. You can reuse your present manifold.
Old May 11, 2013 | 06:58 AM
3JsVette's Avatar
3JsVette
Thanks!
Find another mechanic.
If you bought a car that is all stock and you are looking to keep it that way have the Q-jet rebuilt by someone who knows about them. There are countless forum memebers who are well satisfied with the stock carb after a proper rebuild. The 1st person that comes to mind is Lars. If you do a search using "Lars" you will see what I'm talking about. If you are going go away from stock at least wait till a forum member lists a combination that works. Once you go away from stock you will run into all kinds of issues besides hood clearence like fuel line, throttle cable, choke operation, ect. You get the idea. Don't be in such a hurry that you regret what you did in the 1st place.
Of course this is only my opinion and others will differ.
Welcome to the forum. This place is full of info and opinions. Take advantage of the knowledge and experience. Good luck with your Corvette ownership.
Old May 11, 2013 | 11:16 AM
Shark Racer's Avatar
Shark Racer
Smelling like a gas station could be ignition misfires, sunk carb float, dirty needle/seat, problems with evap system or broken fuel line.
As for the stock intake, you'll only notice whatever performance gain you get from the weight loss. If there's no problem with the stock intake I'd leave it alone and rebuild the QuadraJet.
Where are you located at? Sometimes nearby members will help.
Old May 11, 2013 | 12:02 PM
sassidan's Avatar
sassidan
6th Gear
I'm in Israel. We do have a Corvette community here, and with all the respect to the mechanics here, it's not even close to the knowledge and experience in the states.
Most owners/mechanics here recommended to replace the Qjet, and not rebuild it.
Not sure why.
Old May 11, 2013 | 12:40 PM
scottyp99's Avatar
scottyp99
http://www.summitracing.com/parts/hl...make/chevrolet
If you are willing to convert to an electric choke (easy to do) use this one:
Or, send your Q-jet to Lars. I've never heard anybody complain about his work. Never.
Scott
Old May 11, 2013 | 12:50 PM
qwank's Avatar
qwank
He won't even see any weight loss from the intake swap because the L-82 already has an aluminum intake, and a great one at that.
If your mechanic is absolutely anti q-jet and won;t touch it otherwise, go with the holley spreadbore q-jet replacement like already mentioned, and keep the stock intake
Old May 11, 2013 | 01:06 PM
Paul L's Avatar
Paul L
Actually the L-48 and L-82 shared a common cast iron intake (#346249) 1975-77. The Al intake for the L-82 arrived in 1978.
The suggestion to contact Lars concerning a rebuild is an excellent one! But shipping from Israel to Colorado and back "might" be a little expensive.
Old May 11, 2013 | 01:09 PM
scottyp99's Avatar
scottyp99
Not sure why.
A Holley carb isn't so much better than a Q-jet, but you really have to know what you're doing to work on a Q-jet. They're complicated. Holley's are easy to work with. They're like Lego carbs. So, send your Q-jet off to someone who knows what they're doing, or get a Holley Q-jet replacement carb, and you and your mechanic can mess around with it easily. Six of one, half-dozen of the other. You pays your money, and you makes your choice!
Edit: Yikes!! I just went to Summit Racing's website and checked out how much shipping would be to ship a carb to israel. 260 bucks!! Maybe you could get a friend to smuggle it over in his baggage!!
Scott
Old May 11, 2013 | 01:18 PM
bluedawg's Avatar
bluedawg
Ok so if you dont want to send your carb to lars, which is what I'd do, get a holley ultra hp 650, being as the engines stock, if your transmission is manual, go double pumper, if its auto go vaccum secondaries. Good luck.
Old May 11, 2013 | 02:20 PM
qwank's Avatar
qwank
I never realized that. Thanks
I'd recommend the aluminum version on his car then since you can find them used for a good price
Old May 12, 2013 | 12:04 AM
LastC3AZ's Avatar
LastC3AZ
parts replacement is not always the "easy button" .... just get a carb kit and redo your oem unit .... work with you tech there and you'll all learn a bunch .... you'll stay original and be able to help others over there as well in the future .... IMO
Old May 12, 2013 | 02:32 AM
my 76 ray's Avatar
my 76 ray
Rebuilding a Quadrajet isn't rocket science. Get the rebuild kit and the paper from Lars and try it.
Old May 12, 2013 | 04:43 AM
78SilverCam's Avatar
78SilverCam
Hi,
First and easiest recommendation - replace all rubber hoses.
For the gas smell specifically
3 rubber hoses at the gas tank (fuel/returnn/evap),
4(?) at the Evap Cannister (replace filter as well)
2 hoses at fuel pump
To Need second opinion - carb and intake
