Weight Reduction Program Suggestions requested
Old Jun 22, 2002 | 10:29 AM
flynhi's Avatar
flynhi
Default Weight Reduction Program Suggestions requested
Add to the list of C3 weight reduction items and their weights.
Front End
Remove Front Bumper:
Fixed Headlights/Remove Buckets:
Alum calipers: - 10lbs per wheel
Alum Hub on Rotor
Wheel and Tire combo - your choice from "Wheel and Tire Weigh in"
Steeroids Rack and Pinion - 12 lbs
Alum radiator:
Elect Fans vs Mech:
Fluidamper: -3 lbs
Alum Water Pump:
Alum brackets and pulleys:
Front fiberglass spring: -20lbs
Remove AC
Mini Starter: - 12 lbs
Alum heads
Alum Block (LS-1)-
Headers vs Cast manifold
Hydraulic vs Vacuum Brake Booster
Alum Flywheel: -17lbs
Mid ship
Use 80-82 Glass windshield, side windows:
Use Acrylic rooftops
Late C3 seats vs OE Seats: - 20 lbs
Remove Jack: -
Replace Steel jack with Alum:
Alum Drive shaft:
Remove heater
Remove Radio, Speakers
Rear End
Rear fiberglass spring: -40 lbs
Remove Rear Sta Bar: - 12lbs
Remove spare tire and carrier: -52 lbs
Remove Power Antenna:
Remove Rear Bumper
Help me fill in the missing weights.
[Modified by flynhi, 8:30 AM 6/22/2002]
[Modified by flynhi, 12:37 PM 6/23/2002]
[Modified by flynhi, 12:48 PM 6/23/2002]
[Modified by flynhi, 1:47 PM 6/23/2002]
[Modified by flynhi, 4:09 PM 6/23/2002]
[Modified by flynhi, 8:31 AM 6/24/2002]
[Modified by flynhi, 2:03 PM 6/24/2002]
Old Jun 22, 2002 | 11:55 AM
Fevre's Avatar
Fevre
Default Re: Weight Reduction Program Suggestions requested (flynhi)
If you get a flat, the lack of spare tire will affect you.
Aluminum rims
Aluminum flywheel
Old Jun 22, 2002 | 12:25 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Weight Reduction Program Suggestions requested (Fevre)
This is a general list for everyone, not just your app. You already have some of this, and the 'vert top helps some:
Aluminum water pump, intake. Headers vs exhaust manifolds.
Get rid of things like power antannea and go to a fixed mount.
If you have glass roof panels, get them swapped for the acrylic units (both of my panels togeather weigh less than one glass panel).
How drastic do you want to get? How about things like A/C, heat, speakers and radio?
[Modified by BSeery, 9:26 AM 6/22/2002]
Old Jun 22, 2002 | 12:37 PM
MIKER's Avatar
MIKER
I don't know what parts you would consider as being practical to change out but . . . Like 'em or leave 'em, here are a few suggestions.
Aluminum driveshaft and halfshafts.
80-82 door glass and windshields are supposed to be lighter.
80-82 DANA 44 gear housings are lighter.
Use the lightest weight aftermarket rims vs. good looking ones that are heavy.
Radio delete.
determine if any of the bumper supports / crash protection components can be removed or fabricated from lighter materials.
Old Jun 23, 2002 | 02:02 AM
Stevo81's Avatar
Stevo81
How many pounds do you need to shed?
Old Jun 23, 2002 | 02:55 AM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Weight Reduction Program Suggestions requested (Stevo)
Aluminum block :D copilot seat,flexlite manual fan
Old Jun 23, 2002 | 04:36 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Weight Reduction Program Suggestions requested (Wightnite)
http://www.trimspa.com/products/weight2.shtml?
Hey! Somebody had to say it... :p:
Old Jun 23, 2002 | 04:38 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Here's some things I've done:
Aluminum calipers
Aluminum front hubs (from VBP)
Aluminum radiator
Aluminum water pump
Alumiinum heads & intake manifold
Headers
Fiberglass leaf springs - front&rear
No rear sway bar - up to 12 lbs savings
Lightning holes in headlight action limiting bars - they are the plate steel bars on the side of the headlights - you could fab. aluminum ones
Other things on my do list:
Aluminum drive shaft
Compact spare tire
http://temp.corvetteforum.net/c3/greatwhite/
Old Jun 23, 2002 | 09:37 AM
flynhi's Avatar
flynhi
Default Re: Weight Reduction Program Suggestions requested (Jason Staley)
We've had a number of good ideas posted - now we need the weight savings for each one.
Please list what you know for each item.
Thanks.
Old Jun 23, 2002 | 10:02 AM
Ganey's Avatar
Ganey
Don't forget to remove the heater! Al. heads or at least rect. port BB.
:cool:
Old Jun 23, 2002 | 12:28 PM
terryrudy's Avatar
terryrudy
Default Re: Weight Reduction Program Suggestions requested (Ganey)
Ganey, how much does the heater weigh?
Flynhi, another great post you have going. You may want to take into effect where you are removing the weight. Its obviously more beneficial to remove weight that sits higher up (like heads, acrylic top) as opposed to weight that keeps the center of gravity low like driveshaft, etc.
I too am trying to remove a ton of weight off my car. I think I've taken the horsepower as much as I like so now I'll focus on removing weight. I plan on changing out seats, changing to an astro top, removed spare, have fiberglass rear spring, no rear sway bar, no A/C, aluminum heads and intake.
I can't imagine that a filled aluminum radiator is barely any lighter than a filled OEM radiator. My OEM one was pretty darn light when empty.
The problem with losing weight is that your suspension changes. I noticed that after swapping to aluminum heads my front ride height was raised slightly.
Guess I'll need to cut front springs one of these days to bring it back down.
-terry
ps: once again, good topic; hope it continues..
Old Jun 23, 2002 | 01:52 PM
Matt Gruber's Avatar
Matt Gruber
replace french fries with celery, and you will drop 20lbs within a year. :eek: :lol: :U
Old Jun 23, 2002 | 02:50 PM
flynhi's Avatar
flynhi
Help, please with filling in the missing weights.
TerryRudy - Thanks for the comment
Old Jun 23, 2002 | 03:05 PM
terryrudy's Avatar
terryrudy
Don't forget removing jack too. That sucker is heavy!
As a related note. I was using my dad's jack that came with his '91 Nissan 300Z and that sucker is LIGHT. It looks very similar to my Vette jack but its made of aluminum. Looks really cool and was featherlight. May be a good (relatively cheap) upgrade for those who want to keep spare tire but still lose some weight.
-terry
Old Jun 23, 2002 | 04:28 PM
groovyjay's Avatar
groovyjay
Great topic Flynhi! I think by swapping the brake booster for hydra booster you might loose some weight. I've been a busy boy fabricating aluminum parts. Here's few examples:
This is the inner rear bumber. The original item was 32Kg and this is only 6Kg (sorry, but I don't have a glue what that would be in pounds) and it won't rust either!
This pic shows the use of aluminum on the engine, all brackets, pulleys, water pump, heads, intake etc. Notice the small late model style Power steering pump and the small A/C compressor.
I removed all the orinal A/C stuff and replaced them with Vintage Air's compact gen 2 system. The evaporator is hiding under the stock dash and I filled the ugly heater hole on the fire wall with custom made aluminum plate.
I don't know yet the total weight difference of the car, it was 1640 Kg with half tank of gas and w/o driver. I have pratically replaced everything since, so it'll be interesting to see the difference when it's finished. :cheers:
Old Jun 23, 2002 | 06:10 PM
flynhi's Avatar
flynhi
Default Re: Weight Reduction Program Suggestions requested (groovyjay)
Added a couple of items
Need weights! Help us out.......
Old Jun 23, 2002 | 10:58 PM
Twin_Turbo's Avatar
Twin_Turbo
Mid Ship:
Loose beer gut :D ;)
Marck
To Weight Reduction Program Suggestions requested
Old Jun 24, 2002 | 09:48 AM
Cookwithvette's Avatar
Cookwithvette
Groovyjay, that is one sweet pulley set. Is that one of the serpentine setups that allow you to relax the tensioner and replace the belt in about 30 seconds?
I remember trying to change the belt on my mother's '96 Caravan thinking it was going to be the biggest PITA in the world (aside from spark plugs in that thing which I refuse to touch) but barely took 5 minutes. Takes longer to do a belt swap on a 'vette where all the belts are readily accessable. Giving serious consideration to a serpentine conversion.
Old Jun 24, 2002 | 09:53 AM
Fevre's Avatar
Fevre
Aluminum flywheel weighs 15 lbs while steel ones way between 30 to 35 lbs, savings of about 15 to 20 lbs.
Old Jun 24, 2002 | 11:29 AM
fontking1a's Avatar
fontking1a
For what you're going to spend on getting rid of weight, it might be cheaper to add some horsepower. There's usually two ways...at least....to get the job done. I would invest in some ignition, intake and exhaust parts and then take it from there. You'd be surprised how much hp you can gain with some simple "add-ons".
