Hot 350 or not
Old May 12, 2013 | 01:35 PM
pcguy2u's Avatar
pcguy2u
Default Hot 350 or not
Have an older (classic) vette 350 iron block that I'm trying to get the cooling system under control. Runs at 225 on the highway and hotter than I would like it otherwise.
Tried to check the temps with an infrared meter at a couple of locations on the radiator and goose neck and found something curious. The temps on the bottom of the radiator were much hotter than at the top - 150 vs 110. These are probably low because they are surface readings, but they are relative, and confusing to me as I would have expected them to be just the opposite.
At the time I took these readings, the temp gauge on the dash read 165, so at that moment, the engine was not running hot. After the engine cooled down, I pulled the cap with the engine off, started it up to see if I could tell which way the coolant was flowing, but the only thing that happened was coolant bursting through the cap opening and that was inconclusive.
The pulley setup us a standard v-belt with the fan running clockwise.
Also, talked to the counter guys at the local Napa Auto and the didn’t know of a pump for an older 350 that works CCW They thought the pump impeller may have come loose from the shaft.
One other thought, there is definitey still some air in the system and at the time this happened, the heater core was out of the firewall and hoses were plugged.
None of this seems to make any sense - my search produced no answers.
Old May 12, 2013 | 01:54 PM
bluedawg's Avatar
bluedawg
Did you change the sending unit? I had to change mine due to the spade connector breaking off. This one reads higher, i to used an infared thermometer, and my temps are much lower with it, dont know how much to trust either one. I wonder if the resistance in the new one is different, causing a different reading?
Old May 12, 2013 | 03:02 PM
pcguy2u's Avatar
pcguy2u
Ok, so I was not able to run the engine with the cap off because coolant went everywhere. So I took an old radiator cap, removed the lower rubber gasket and drilled a 3/16” hole in the stainless steel backing plate. Installed the cap removed the overflow hose and connected a 5/16” translucent plastic hose and put the end into a plastic milk jug, just in case.
Well, initially the fluid came up about 18'” and air started bubbling out and slowly the level came down and at times disappeared. I was somewhat concerned that what I was looking at was a head gasket problem, but eventually, I could race the engine (3-4k) and very little coolant would show and when it did, air also escaped. Have shut off and restarted numerous times and each time more coolant/air comes out and goes back to no coolant showing.
Could all this have to do with too much air?
Old May 12, 2013 | 04:07 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
why are you not investigating the thermostat?
Old May 12, 2013 | 04:08 PM
terrys6t8roadster's Avatar
terrys6t8roadster
is this a c-3? both of mine whenever the cooling needed refilling I had to cycle the system 3 to four times and added fluid every time until it was about 2" down from the neck. I can run the engines up to temp with the cap off and it does not bubble out. the coolant flows out of the core into the right tank. check the coolant level the next day after the pressure has subsided. bad head gaskets on sbc is rare but does happen. the way I like to fill the system is to put as much coolant into the system leave cap off come back the next day add more. it seem as if you don't have enough coolant in system and air is being pumped into the block heated by a running engine expanding and pushing out the coolant. hope this helps
Old May 12, 2013 | 04:34 PM
pcguy2u's Avatar
pcguy2u
The thermostat is new and opens at the right time and the old 180 was doing the same thing.
Only a C-3 engine and radiator, they're in a 75 Vega. Here's some more info:
The thermostat/cap/neck are all together on the intake manifold and there is no space for moving coolant above the coolant level which is just below the seal in that very small chamber just above the thermostat. The raidator is a closed subject and there it no veiwing the inside, but the level of the coolant in the neck is near the top of the hose going into the radiator which leave room in the top of the radiator for expansion.
This looks like the problem is either too much air in the system or a radiator that needs cleaning. Of course, I don’t have much experience with either.
There are no leaks and there is a coolant recovery system. No smoke, no coolant in the oil and no oil in the coolant.
Old May 12, 2013 | 07:21 PM
scottyp99's Avatar
scottyp99
As I'm sure you know, this is a corvette forum. There are a lot of people here who are experts on corvettes. But your corvette engine and radiator in a vega is not a corvette. Who knows what has been changed in the swap. Radiator height compared to the engine, radiator angle, amount of airflow available, just to name a few. So, you may not be able to find the help you need from corvette experts. Some pics would be a big help. Sorry I can't be more helpful,
Scott
Old May 12, 2013 | 10:07 PM
PeteZO6's Avatar
PeteZO6
If I understand your statement "the radiator is a closed subject" correctly your rad does not have a radiator cap. If this is the case, you NEED an expansion tank like ALL Corvettes with cap less radiators had. Like in this photo:
The coolant level in the tank is about half way up, the rest is air. The tank is located higher than the top of the rad and the thermostat. If you do that, you can get rid of that thermostat housing/cap lash up and rid yourself of the problems you are having.
That small hose going off to the left of the photo goes to a fitting on the top of the rad so air can escape the rad.
Hope this helps!
Pete
Old May 13, 2013 | 12:39 AM
bluedawg's Avatar
bluedawg
Scott
Corvette snob....nice, id give ya thumbs up but im cellular right now, so imagine a thumbs up....
Old May 13, 2013 | 09:34 AM
pcguy2u's Avatar
pcguy2u
Hope this helps!
Pete
And here I thought I was plagued with the other car Syndrome - so it appears that some of these Corvette experts are able to interpret across lines - thanks for that Pete - right on and very helpful. I wonder how difficult it will be to install the fitting in the radiator or maybe it's there already and plugged. Have had the radiator out and it comes out from under the car and can't recall seeing the fitting/plug - a real PITA.
Old May 13, 2013 | 10:48 AM
pcguy2u's Avatar
pcguy2u
Two other questions Pete, is the hose on the lower right of the tank connected to the tank and where does the other end connect?
Many thanks,
Nick
Old May 13, 2013 | 11:02 AM
PeteZO6's Avatar
PeteZO6
Many thanks,
Nick
Good question, I neglected to mention that in my previous post. There are two fittings on the bottom of the tank. The tank is connected between the heater core and the water pump, the return line from the heater. If you don't have a heater, you could connect that side to the intake manifold fitting that would supply the heater. The heater itself isn't important, it is just the way GM got the tank into the cooling system so the cap and air space for coolant expansion is above any other part of the cooling system.
As for the fitting on the top of the rad that connects to the tank, this image should give you an idea of what it looks like. http://www.dewitts.com/collections/c...minum-radiator
It is that little hooked shaped pipe on the top right.
Pete
PS. I used to live over the hill from you in Cotati & Petaluma. Great Corvette roads over there.
Old May 13, 2013 | 11:10 AM
Mike Ward's Avatar
Mike Ward
Can you post of pic of the rad? I'm curious to see what year/engine it may have come from. The comments about requiring an expansion tank are spot on.
Old May 13, 2013 | 11:17 AM
pcguy2u's Avatar
pcguy2u
You can't see any part of the radiator except the fins in front of the water pump fan. No shroud and a pusher electric fan on the front side.
Even the top is enclosed in the body framework - that's why it has to come out from the bottom.
Tanks are on the sides (4 tubes on the fins) and the flow is from the drivers side to the passeger side.
Old May 13, 2013 | 11:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
C3 radiators are designed to be mounted with a backwards tilt toward the fire wall. If you have it mounted straight up and down in the Vega, it is not cooling as efficently as designed.
Old May 13, 2013 | 11:46 AM
scottyp99's Avatar
scottyp99
Not being a snob, just pointing out that the OP has taken a corvette engine and cooling system and made changes to it, so a corvette expert may not be the best person to ask for advice. On the other hand, there are plenty of people here who have lots of experience with Frankenstein projects, and can be of great help. And I'm sure they will be. Again, pics would help. Sorry if I came off sounding snobby, didn't mean it to sound that way.
Scott
Old May 13, 2013 | 12:00 PM
scottyp99's Avatar
scottyp99
I don't think they were designed to be placed at an angle, that's just what they had to do to fit it in there. It's still just a conventional radiator, if you really look close. Actually, I think the fact that our radiators are mounted at an angle may be a factor in why so many corvettes have marginal cooling systems. I'm not an expert, so I admit I could be totally wrong here, if I am, could somebody straighten me out on the subject? The only reason I'm even mentioning this is because I think it will have an effect on the OP's decisions.
Think about the basics: if there is sufficient coolant flowing through the radiator and engine, and there is sufficient air flowing through the radiator fins, it should just work. I know this sounds obvious, but sometimes we overlook the obvious. It's never a bad idea to start at the beginning. One last thing: Pictures!!!!!
Scott
To Hot 350 or not
Old May 13, 2013 | 01:31 PM
pcguy2u's Avatar
pcguy2u
Might be a little confusing, but here goes. Right in the center is the radiator cap and the translucent hose coming of the neck on the left is the same hose coming back down on the right – it is then connected to my vacuum gauge. The way I made this work was to remove the lower rubber sealing gasket from an old cap and then drilled a 3/16” hole in the base behind that gasket. This allows the system to be sealed for pressure and to force any pressure into the translucent tube where I can see any coolant/bubbles.
Here’s a picture of my setup with my pressure test still in place – BTW, I ran the engine this morning, stone cold, with this setup/vacuum/fuel pressure gauge in place this morning and the only motion on the needle was a very slight movement toward vacuum. This seems reasonable because the water pump would be pulling on the cap and that provides some indication that a head gasket leak is less likely, at least when the engine is cold.
Hope this helps....
Old May 13, 2013 | 02:05 PM
bluedawg's Avatar
bluedawg
You never answered the first question about the sending unit. Are you using the one from the vette, Vega or aftermarket?
Old May 13, 2013 | 02:14 PM
pcguy2u's Avatar
pcguy2u
Sorry, it's an after market analog - here's a picture. Should actually read Temp Gauge sending unit location. Plug wires are the old ones and have been replaced/rerouted.
