Which 454?
Old Oct 29, 2004 | 04:54 PM
PRNDL's Avatar
PRNDL
why did this 2yr old thread get brought back?
Old Oct 29, 2004 | 05:01 PM
PRNDL's Avatar
PRNDL
Old Oct 29, 2004 | 05:02 PM
LS WON's Avatar
LS WON
Originally Posted by Brettmc
WHEW!! I'm glad this is opinion and not the norm.....
Brett
KEY WORDS "FRAME OFF RESTORATION".
Old Oct 29, 2004 | 05:05 PM
GDaina's Avatar
GDaina
Brett
Opinion, yes, truth, yes, just look at the big buck auctions, the high dolloar vettes are all stock, number matching. Granted, they appear to have original motors, trans, etc.
To answer the Q asked, does not make any sense to spend more $$$$ on rebuilt hardware when new equipment can be purchased for less. One would have to have rocks for brains to to buy Beck vs GM crate.
Old Oct 29, 2004 | 05:06 PM
Fevre's Avatar
Fevre
I opened the thread and started reading, after reading the first responce and thought 'I'm with this guy' then notice it was me who wrote it.
Old Oct 29, 2004 | 05:08 PM
GDaina's Avatar
GDaina
It happens with the archives....the boys must be doing something....don't feel bad, I got cought as well when I replied. I even saw our friend Georgie in this thread....I thought WTF....how did he get back?
Old Oct 29, 2004 | 05:27 PM
LS WON's Avatar
LS WON
And another reason why I am retired now.
Old Oct 29, 2004 | 09:04 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Obdoc finished his engine a while ago.
Old Oct 29, 2004 | 09:56 PM
68/70Vette's Avatar
68/70Vette
For your frame off 454 project, here's another thing to spend money on! Have the 454 internally balanced. Normally the balance weights are in the flywheel and crankshaft damper. You really have to balance the pistons/con rods at the crankshaft throws. The 454 can be internally balanced by adding tungsten plugs to the crankshaft throws. This relieves internal unbalance and means you can run a "neutral" flywheel and crankshaft damper. The 427 is the only BB engine that is naturally internally balanced. I think that's why the 427's were so popular for long distance races. A little bit of overkill for the street. But internally balanced means you can rev your big block with a lot less internal stress. I don't think the cost of internally balancing a 454 is really all that much.
Old Oct 29, 2004 | 11:29 PM
GDaina's Avatar
GDaina
Would you believe a 533 cube inch is a naturally internally balanced?
Old Oct 30, 2004 | 08:19 AM
'69CoupeDude's Avatar
'69CoupeDude
The 454 HO has rectangular port iron heads and comes with a high rise intake so hood clearance can become an issue.
If you're looking for aluminum heads you might consider the ZZ454. It has the same short block as the 454 HO but has oval port aluminum heads, p/n 12363390, and comes with a different high rise intake. The GM Performance Parts Catalog warns, "It will not fit on many Corvette models with manifold height at 6" in rear and 4" in front."
Old Oct 30, 2004 | 09:29 AM
MyBoTy's Avatar
MyBoTy
Pick up a good short block and buy my GMPP/Edelbrock aluminum ovals. I don't need 'em, they're brand new and I'll save you $150 off the cost from GM. They're complete with 2.25/1.88 valves and couble springs, set up for roller and I also have a used Performer RPM for cheap. By the way, what happened to the original engine or are you upgrading to a big block?
Gary Adrian
81vette4speed@***.net
Old Oct 30, 2004 | 05:43 PM
  #33
Stoge's Avatar
Stoge
That guy was something else!
