Which 454?
Old Jun 22, 2002 | 11:57 AM
Obdoc's Avatar
Obdoc
Default Which 454?
I need some opinions. I am currently in the middle of a frame off restoration on my '72. Now is the time to place the engine on the rolling chassis. I have decided on a 454 motor, however, I do not know which 454 to get. Should I purchase the GM 454 HO crate engine or purchase a rebuilt unit from Beck Racing?
The way I see it, the GM 454 has a new 4 bolt main block, new forged pistons, new rods, and new forged crankshaft. But, the Beck Racing 454 has a rebuilt 2 bolt main block, hypereutectic pistons, rebuilt crankshaft, and rebuilt heads. Plus the Beck Racing engine is more expensive.
:crazy:
Please help.
Old Jun 22, 2002 | 12:03 PM
Fevre's Avatar
Fevre
Default Re: Which 454? (Obdoc)
I would go the new GM route. Drive the **** out of it until the warranty is up then start the mods/upgrades. At that point you will have a good idea of how much you want to do. Also you will have the money that you did not spend on the other engine and any you save up to pay for the new mods. I bought a cheap GM 350 and snuck a bigger cam in before i put it in, just don't tell GM. ;)
Old Jun 22, 2002 | 12:13 PM
PRNDL's Avatar
PRNDL
Default Re: Which 454? (Fevre)
You have a choice between a more expensive used (rebuilt) engine and a brand new waranteed GM engine? hmmmmm...... How much more hp/torque is advertised with the Beck engine? I guess you might want to hear from people with experience with Beck, but I dont see much of a choice myself. MJ
Steve Straus's Avatar
Steve Straus
If you have a 4-speed you'll have to fabricate a bracket for the clutch cross-shaft, as there is no boss on the 454 HO to mount it to. Also, there are no provisions for a mechanical fuel pump, so you're forced to go electric. It's a Gen V block.
Old Jun 22, 2002 | 12:41 PM
tworottiedogs's Avatar
tworottiedogs
Default Re: Which 454? (Steve Straus)
The 454HO does have fuel pump provisions.
Old Jun 22, 2002 | 12:45 PM
PRNDL's Avatar
PRNDL
Default Re: Which 454? (tworottiedogs)
Steve, I believe you cited the probs with the 502 (fuel pump and clutch linkage). The GM crate 454 does not have those problems and is more of a direct replacement. (I forget which "Gen" is which). MJ
Old Jun 22, 2002 | 01:01 PM
Obdoc's Avatar
Obdoc
Default Re: Which 454? (MNJack)
Yes, the 454 has the mechanical fuel pump provisions. It is a Gen VI block. As for the Beck engine, it is advertised at 502 hp and 500 ft-# of torque. What about changing the heads on the GM crate engine to aluminum heads?
[Modified by Obdoc, 11:53 PM 6/22/2002]
Old Jun 22, 2002 | 01:16 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
[Modified by Obdoc, 12:08 PM 6/22/2002]
I'm using an '87 Mark IV, 4-bolt main block with the GM, 2.25 valve, 110cc chamber aluminum heads. For what it's worth, I think the LS-5 was a two bolt and the LS-6 a 4 bolt.
As for Beck racing engines-----ask BionicVette from Hawaii. He got the 'ol Beck racing screw job.
Old Jun 22, 2002 | 01:53 PM
bigvette1's Avatar
bigvette1
GMPP is the way to go. 454/425 at 500ft lbs is a super engine. Warranty and cheaper add to the incentive.
Old Jun 22, 2002 | 05:16 PM
73-454's Avatar
73-454
You can't beat New. I would buy New over rebuilt any day unless I was on a budget and the rebuilt was 1/2 the price.
Old Jun 23, 2002 | 09:44 AM
Tominator's Avatar
Tominator
The GM sure looks like a nice motor, hell of a bang for the buck.
Old Oct 29, 2004 | 03:07 PM
DropTopBigBlock's Avatar
DropTopBigBlock
Some of the LS5's were 4-bolt, some two; only way to tell is drop the oil pan. I'm looking at a rebuild soon, though, and I'll be doing a GM 454 shortblock rather than mess with it.
Old Oct 29, 2004 | 03:59 PM
Ironcross's Avatar
Ironcross
Simply put, "Go new"
Old Oct 29, 2004 | 04:08 PM
Brettmc's Avatar
Brettmc
The HO454 is way overbuilt with all the forged internals and 'only' a ~450 hp rating. This would be an excellent base for future mods.
Old Oct 29, 2004 | 04:17 PM
dragonracer's Avatar
dragonracer
a very buildable base!
Old Oct 29, 2004 | 04:19 PM
dragonracer
a very buildable base motor
Old Oct 29, 2004 | 04:22 PM
evelkevin's Avatar
evelkevin
Also don't forget the GM hi rise aluminum intake will not fit under a stock hood.
If you do your homework, there are some nice generation IV 454's and bigger being built out there. If you don't have a 4 speed or mind an electric fuel pump the GM gen VI is the way to go....the 502/502 base is a nice alternative
To Which 454?
Old Oct 29, 2004 | 04:33 PM
LS WON's Avatar
LS WON
Keep it GM even better factory stock if you want to retain value and appreciate in value. The Car is worth more now factory stock than it was bought brand new in 1972 in the $5,000 to 6,000 price range. Everyone likes the factory conditon car if it is modified then it will only cater to the individual who decided to go that route to butcher a pure bred and depreciate it in value. Depreciate the value is by finding out the costs of bringing the car back to factory specifications and deduct that cost.
Old Oct 29, 2004 | 04:44 PM
Brettmc's Avatar
Brettmc
WHEW!! I'm glad this is opinion and not the norm.....
Brett
Old Oct 29, 2004 | 04:51 PM
PRNDL's Avatar
PRNDL
why did you dig up this 2 yr old thread?
