HP Increase
Old May 17, 2013 | 04:23 PM
scottyp99's Avatar
scottyp99
Originally Posted by Yeller81USNRet
Ok Guys here we go The Cam is:
intake @cam 296
Exhaust @ cam 311
@intake valve 444
@exhaust valve 466
Edelbrock 1406 Carb.
Hope this helps and dual exhaust inch and 5/8 " Headers
Is this your cam?
http://www.summitracing.com/parts/su...make/chevrolet
Scott
Old May 18, 2013 | 08:33 AM
Yeller81USNRet's Avatar
Yeller81USNRet
This is the Cam:
Brand:Summit Racing
Manufacturer's Part Number:SUM-1103
Part Type:Camshafts
Product Line:Summit Racing® Camshafts
Summit Racing Part Number:SUM-1103
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,600-5,200
Intake Duration at 050 inch Lift:214
Exhaust Duration at 050 inch Lift:224
Duration at 050 inch Lift:214 int./224 exh.
Advertised Intake Duration:288
Advertised Exhaust Duration:298
Advertised Duration:288 int./298 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.444 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.466 in.
Valve Lift with Factory Rocker Arm Ratio:0.444 int./0.466 exh.
Lobe Separation (degrees):112
Computer-Controlled Compatible:No
Valve Springs Required:Yes
Camshaft Manufacturers Description:Fair idle, low midrange torque/horsepower, works well in 327 and higher c.i.d. engines. Largest camshaft with stock converter.
Quantity:Sold individually.
Free CatalogRequest a Catalog from the World's Speed Shop
From low-end torque to top-end horsepower--and everything in between--one of our Summit® cams has you covered. Assembly lube is included.
Old May 18, 2013 | 09:17 AM
qwank's Avatar
qwank
that looks very similar to an L-82 cam. I think you may have even gotten more with an actual L-82 cam.
with the cam you installed your stock carb and distributor probably would have worked better than the Edelbrock and saved you some money
