HP Increase
Old May 16, 2013 | 10:21 AM
Yeller81USNRet's Avatar
Yeller81USNRet
Default HP Increase
I just removed the E4ME Carb and Dizzy and put on a set of headers and a mild cam and removed all the smog components and the A/C compressor got a Edelbrock carb now.Any idea on any HP Increase due to these Mods ???
Old May 16, 2013 | 10:33 AM
my 76 ray's Avatar
my 76 ray
Without specs on the cam there's no way to guess.
Old May 16, 2013 | 10:34 AM
qwank's Avatar
qwank
-20 because of the carb
Old May 16, 2013 | 10:45 AM
Mike Ward's Avatar
Mike Ward
probably not -20, but certainly no + anything.
The smog removal = no gain.
AC compressor, no gain as it draws no power when turned off
Distributor could be a minus if not set up properly
Old May 16, 2013 | 02:22 PM
augiedoggy's Avatar
augiedoggy
You didn't state which size Carb..... I'd say a 5-10 hp from the removal of the air pump....distributors usually give you no gain less its a custom advance curve over stock or your having issues at high rpms. (Which isn't a concern on a stock engine) performance wires and coils are more advertising and do little if anything for a street engine most who claim power increases just had worn out failing equipment prior to purchase and replacement.
Old May 16, 2013 | 03:43 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Headers. No real gain without dual exhaust.
Old May 16, 2013 | 03:50 PM
Shark Racer's Avatar
Shark Racer
The power difference between a well set up Quadrajet and a well set up Holley, of equal size, will be within the margin of error on the dyno.
As others have mentioned, the cam will have the biggest "power" difference. I think the headers will help a little but would be greatly magnified by opening the exhaust up.
I also agree with the sentiment on the distributor; it depends on how well set up it is.
Old May 16, 2013 | 03:51 PM
scottyp99's Avatar
scottyp99
I will answer your question if you answer mine. I recently started exercising and eating healthier, how much weight have I lost?
See, it's the same kind of question. Does it feel like it's got more power?
Scott
Old May 16, 2013 | 03:56 PM
scottyp99's Avatar
scottyp99
Good point. The conventional wisdom says that you are better off with stock manifolds and a free-flowing dual exhaust, than headers dumping into the restrictive stock exhaust.
Scott
Old May 17, 2013 | 12:24 AM
MakoJoe's Avatar
MakoJoe
Well like the others have said not really enough information to tell.
I can tell you where I live removing the Smog Components will disqualify me from running my car in the county I live in
Removing components off the car will like the A/C unit does nothing if you never used it. It is about a 5 HP gain from non use.
Dual exhaust will actually provide between 10 to 20 Horse Power gain from a single exhaust system depending on the mufflers. Mild Cam 10 to 20 HP. Headers and open exhaust another 10 to 20 HP
You never really know until the engine is sitting on Dyno and the calculate the Drive Train into the Dyno readings with the Gear Ratio. Net horse power is what they calculate
from the rear tires.
You want HP get a 383 Stroker kit installed for between 300 to 350 HP . Other wise on a Stock L48 Engine breathing well with a few modification will probably never get passed 230 HP on a dyno.
Old May 17, 2013 | 08:08 AM
augiedoggy's Avatar
augiedoggy
I disagree.
Replacing the heads on an l48 with say 64 or 58 cc heads with thinner head gasket and better quench will bring the compression up to around 9:5 conservatively ... that along with the rest of the bolt on mods will bring the engine well past 230hp ..... The only things different about the l48 block that effects power produced is the cam and dished pistons... small cc chambered heads cure that issue and the cam is easy enough to change.
The other differences IE 2 bolt vs 4 bolt and cast crank vs forged are really a non issue untill your creeping up to 500hp or your beating on it.
Some of the confusion here is rear wheel vs engine hp....400hp 350 which is not hard to make should give you 300-340 rwhp... but that kind of setup will want to make its power in the higher rpm range hence the higher stall converter and rear gear change. Good heads and cam are the foundation for all other bolt ons to live up to their potential as I see it.
Old May 17, 2013 | 08:43 AM
oldschoolvette's Avatar
oldschoolvette
Scott
8 lbs...
seriously as stated above, you cant solve the equation without more data..
A + X = 9 solve for X? X could be anything depending on A value
help us out here
Old May 17, 2013 | 08:56 AM
augiedoggy's Avatar
augiedoggy
Originally Posted by oldschoolvette
8 lbs...
help us out here
I think its safe to assume everything is stock 1981 except what the OP mentioned as mods and hes looking for a rough ballpark.. My guess is he doesnt know what "mild cam" is installed.
Old May 17, 2013 | 10:59 AM
Shark Racer
Neither do we, is the point.
Old May 17, 2013 | 12:07 PM
augiedoggy's Avatar
augiedoggy
arent his Mild cam choices fairly limited with stock heads and lift? can ithe power really vary that much being that its still limited by stock heads and exhaust?
Old May 17, 2013 | 01:34 PM
bashcraft's Avatar
bashcraft
help us out here
Simple, X = 9 - A
Old May 17, 2013 | 02:00 PM
scottyp99's Avatar
scottyp99
Originally Posted by bashcraft
Simple, X = 9 - A
I think you got him there, bash! But it still doesn't really help us figure out the value of X, does it? For the purposes of this discussion, it's like saying "Your engine is now putting out however much it did before, plus the amount of horsepower increase." Well, that's true, but it doesn't really tell us much. I like your style, though, wiseguy!
Scott
To HP Increase
Old May 17, 2013 | 02:27 PM
Shark Racer
True enough. I'd estimate he's gained somewhere between -10 and 30 horsepower.
Old May 17, 2013 | 03:34 PM
Yeller81USNRet
Ok Guys here we go The Cam is:
intake @cam 296
Exhaust @ cam 311
@intake valve 444
@exhaust valve 466
Edelbrock 1406 Carb.
Hope this helps and dual exhaust inch and 5/8 " Headers
Old May 17, 2013 | 03:38 PM
jotto's Avatar
jotto
As said above, not enough info....
Headers would gain some if you replaced the rest of the exhaust otherwise your just flowing into the same restrictions.
Smog components use diddly squat but it sure makes the engine bay look cleaner.
Is the distributor properly recurved for your engine and is the carb set up correctly or just installed out of the box?
Again AC compressor......did you use it before? No real gains apart from cleaning up the bay.
Cam, is it well matched to what you have? we need specs. No point having a cam that doesnt work with everything else.
I have an '81 so am interested in what you have done.
