Headlight Assembly
Old May 20, 2013 | 09:32 PM
losmartinez's Avatar
losmartinez
Cruising
Default Headlight Assembly
Can anyone let me know if there are differences between the 1977 headlight assembly application and a 1972 application? I have found so far that the inside brackets closest to the nose are shorter on the 77 application. Is this correct or did I install incorrectly? For clarity, I have 1977 headlight assys and I am wanting to use them on a 1972 frontend...is this doable? Thanks....
Old May 20, 2013 | 11:53 PM
wombvette's Avatar
wombvette
The support brackets are significantly different because of the bumper and front end shape. Everything else is the same.
Old May 21, 2013 | 09:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What he said.
Old May 21, 2013 | 12:52 PM
losmartinez
Cruising
Cool...thanks for the reply all. Just as I thought...so before I hit the Internet...would these support brackets be available or would I have to get the entire assy? Thoughts?
Old May 21, 2013 | 01:10 PM
Alan 71's Avatar
Alan 71
Hi l,
The supports are available from various vendors, and you may also find them used too.
Not inexpensive!
Regards,
Alan
To Headlight Assembly
