crate plans for '75
Old May 21, 2013 | 03:25 PM
brianPA's Avatar
brianPA
Default crate plans for '75
The clutch on my '75 4spd is toast and I've been wanting to put a crate in to replace my original l-48 with ~80k miles. I'm going to have both done at once. I was originally planning to do the clutch first myself and drive it until the motor dies, but I broke my hand earlier in the season and at this rate I'll never get it done on my own.
I have a holley 4150 w/lars-style dual fuel lines, patriot true dual exhaust (I think this is D port? http://www.parts123.com/parts123/yb....~~~~~~0000050Q ) and stock hood with stock 4spd.
I am planning on a ZZ4 but I see the Fast Burn and ZZ383 are highly recommended also, though not sure they will match my headers well. I don't want to have to replace the transmission or diff any time soon if I can avoid it so I assume I'm limited to ~400hp based on what I've read.
Is this all likely to work well together?
Old May 23, 2013 | 01:37 AM
bluedawg's Avatar
bluedawg
If I were picking between the 3 it would be the zz383.
Old May 24, 2013 | 12:53 PM
7t9l82's Avatar
7t9l82
why limited to 400 h.p ? if you are concerned about the rear , the L-88 and LS-6 corvettes used essentially the same rear you have both were waaaay over 400 h.p.
To crate plans for '75
