Brake issue
Old May 22, 2013 | 06:33 AM
Iron_dog's Avatar
Iron_dog
Default Brake issue
Hi, I'm trying to explain the brake issue I have.
When I take the car for a trip after a couple of weeks the brakes (power brakes) don't work. After some pushings on the brake pad and some miles (carefully), they start to work on one side (I feel the car sliding on one side when I brake and I have to correct with the wheel) and then finally after some more miles they resume their functioning.
What is the root cause? Air inside the circuit or low brake fluid? How to check for them?
thanks
Old May 22, 2013 | 09:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What's the overall condition of the brake system? Have you done any brake work? Do you need brake work? Have you done any maintenance on the system? Have you bled the system?
C3 brakes are front and rear. One side cannot be working and the other not working without serious issues in the system.
Why not take it to a shop and have a pro take a look at things to give you a reference point?
Old May 22, 2013 | 09:16 AM
Iron_dog's Avatar
Iron_dog
Braking system had been upgraded to power brake one year ago from a shop, and it worked ok. It has started to have problems after the winter, when I don't use the car so much...
Old May 22, 2013 | 12:03 PM
78SilverCam's Avatar
78SilverCam
Are you using the original calipers?
If so it may be due to the design flaw of the lip seals over the caliper bores. Did you notice brake fluid on the floor near the tires? Did you check the master cyclinder to make sure it was still topped up?
If the master cylinder is low/empty then you will have to bleed the entire system - starting with a bench bleed of the master cylinder and then working on the calipers. (shameless plug for Motive Power Bleeder here).
Old May 22, 2013 | 12:57 PM
iokepakai's Avatar
iokepakai
Will be upgrading to the Wilwood D8 calipers.6 piston front and 4 piston rear.Aluminum body much lighter than stock and hear they are easy to bleed, unlike the stock units.Van Steel is giving a discount to forum members!!
http://www.vansteel.com/index.cfm?fu...&SubGroup=1962
Old May 22, 2013 | 01:05 PM
Tjf2000's Avatar
Tjf2000
What s the coupon code?
Old May 22, 2013 | 03:39 PM
JKintzel's Avatar
JKintzel
Over 30-years ago I had similar brake problems with "Stock Brakes" on my 73. Original design flaw caused corrosion between piston and calipers. That's why a guy from the Buffalo, NY Area started Stainless Steel Brakes, not far from where I live. Essentially all he did was bore out the stock GM caliper and put a stainless steel sleeve and piston in. It was an upgrade just about everyone made until GM corrected the problem in later years. Brake technology has come a long way, so you have many good choices available.
Old May 22, 2013 | 09:17 PM
TCracingCA's Avatar
TCracingCA
Default Reply!
thanks
Yes your description is a little vague, but I think I have it. The brake booster operates off of vacuum. Thus I would explore a vacuum related cause. Some times they feel pumped up and at times not. Also the air in the line is a possibility in the one side engaging while the other side just seems to travel on. Thus is the car pulling to one side or the other? I would give it a good ole sudden hard stop test to see. The C3 cars are very difficult to bleed the rears. Sometimes the dimished effect of air in the rear can give the sensation of the overall braking ability being dimished.
Also all of the other posts were good in the recommendations to stainless sleeves and I would step up to the pistons so they are all matched and expanding with heat equally.
The booster is difficult and on one, even though it was newly purchased without hope of return, we used silicone to seal it on the body. The very small leak was just enough, that on a short drive or if the brakes weren't being consistently applied, then we would have what seemed like changing symptoms.
Old May 24, 2013 | 05:27 AM
Iron_dog's Avatar
Iron_dog
Thank you guys for the tips!
Right now I have no leak and brake level seems ok.
The good thing is that, if I use the car every week, I don't even notice this issue, I have to leave the car sitting for one month... as I did during the winter.
I will also consider to upgrade brake system in the future, but only when I raise the power of the stock L48...
Old May 24, 2013 | 12:24 PM
78SilverCam
If sticking with the original system (if it ain't broke don't fix it) then I would still suggest doing a brake overhaul simply as routine maintenance.
There are two main reasons I suggest this:
1) Unless done regularly, your brake fluid may be more like brake SLUDGE .
I did an MC/Caliper overhaul and the brake fluid was disgusting.
2) When doing an overhaul, you may find something that could explain your problem.
For example, when I did mine I found that the pistons were pitted and needed to be replaced. On top of that, you are able to really get in the brake system and clean it out.
You will have to replace the lip seals which is minimal cost. You may uncover things that will cost more money...
To Brake issue
