brake problems
Old May 23, 2013 | 10:24 AM
corythevette's Avatar
corythevette
1st Gear
Default brake problems
I own a 1972 corvette without power brakes. It has been in storage for about 1.5 years. The master cylinder had lost its brake fluid during storage in the front half of the cylinder. The back half is OK. I replaced the leaking right caliper and power bled the system. The brake pedal still initially goes all the way to the floor when pressed, but will then build pressure when pumped. As soon as I reduce pressure on the pedal, it goes all the way to the floor when I press again. What could be causing the problem?
Old May 23, 2013 | 11:42 AM
my 76 ray's Avatar
my 76 ray
Air in the system or a leak. It's probably air in the master cylinder. If it was empty it needs to be bench bled to get all the air out of it. The outlets are not at the very top of the piston bore so it needs to be tilted in order to get all the air out.
Old May 23, 2013 | 12:14 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by my 76 ray
...It's probably air in the master cylinder...
Old May 23, 2013 | 12:20 PM
MelWff's Avatar
MelWff
Another possibility is the master is bad, the rubber seals can break down and corrosion can build up in the bore of the master. When you press the pedal all the way to the floor the rubber seals on the piston scrape past the corrosion point and sustain further damage.
Old May 23, 2013 | 04:02 PM
gcusmano74's Avatar
gcusmano74
The front half of the master cylinder serves the front brakes. Check them first.
To brake problems
