Space to remove front springs
Old May 25, 2013 | 08:48 AM
1974ta's Avatar
1974ta
Default Space to remove front springs
I understand the front springs are pretty long.
How high will I need the front end off the ground to use the floor jack when removing the front springs?
I will also be using the kent moore tool so I do not have to separate the ball joints per the service manual.
Thanks!
Bill
Old May 25, 2013 | 09:03 AM
wombvette's Avatar
wombvette
Look at the pivot point, in that case the ball joint. High enough to let the arm down straight.
That distance is a lot less doing it by removing the joint because the shaft pivot is higher up.
Old May 25, 2013 | 09:07 AM
SH-60B's Avatar
SH-60B
Never heard of a kent moore tool. I get the tire about 8" off the floor to do anything with the front suspension. If you're not breaking a ball joint (no big deal really) you're unbolting the LCA mounts to get the spring out that way. 6 of one, half dozen of the other.
Old May 25, 2013 | 09:13 AM
oldalaskaman's Avatar
oldalaskaman
if youre talking about disconnecting the lower control arm mounts , get the car as high as a floor jack will lift it , put a jack stand under the frame, put pressure on the lower control arm, and use the floor jack to lower the control arm, with the spring compressed , should drop right out. also a good time to replace lower control arm bushings, you still need to take the tie rods and sway bar loose.
I've done this both ways, bout the same work either way, only advantage to this is youre not beating on a marginal ball joint
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
What's the kent moore tool was that something invented by Kent Moore ?
Take the wheel off and you are pretty much at the right height, if not jack it up higher
Old May 25, 2013 | 09:28 AM
Alan 71's Avatar
Alan 71
Hi Bill,
The free height of a front spring is about 15 1/2".
If you compare that number to the compressed height it might give you some idea about how high the car needs to be.
I'd think that difference, plus maybe 6", plus the height of the K/M tool and jack.
Regards,
Alan
Old May 25, 2013 | 11:26 AM
qwank's Avatar
qwank
Kent Moore is the company that makes all the special tools for GM. sometimes also referred to as "J tools"
Old May 25, 2013 | 12:05 PM
Alan 71's Avatar
Alan 71
Hi,
Something else about the K/M tools.
At the end of each Section in the Chassis Service Manual there's a complete list with part numbers, and a photograph, showing the all the K/M tools used in that Section.
I wonder if the 'dealer' was required by GM to have those tools in their shop?
Regards,
Alan
Old May 25, 2013 | 12:09 PM
qwank's Avatar
qwank
Originally Posted by Alan 71
Hi,
Regards,
Alan
yes, they are required, and they have to pay for them whether they want them or not. I work at a dealer and we're always getting new tools sent to us. They just show up with a bill.
Old May 25, 2013 | 12:41 PM
MotorHead's Avatar
MotorHead
You can knock the ball joint loose or take the bolts out of the lower control arm, what magical thing does the KM tool do ?
Old May 25, 2013 | 01:15 PM
gcusmano74's Avatar
gcusmano74
Only that the ID of the Corvette springs is rather small. Some of the spring removal tools on the market will not fit. In which case, support the lower control arm with a hydraulic jack, remove the lower control arm bolts, and slowly lower the control arm to remove the spring. Be afraid the whole time; the compressed spring has enough stored energy to hurt you badly. BE CAREFUL.
Old May 25, 2013 | 09:09 PM
1974ta's Avatar
1974ta
Default Tool
The Kent Moore tool should allow a little more control when lowering the control arm to free the spring.
I am doing this so I can remove the spring to insert the tool to remove the dent.
Thanks for all the input.
Bill
Old May 26, 2013 | 03:32 PM
oldalaskaman
wilcox has a vid of a home made tool, does the same thing, costs bout $8 bucks
Old May 28, 2013 | 07:28 AM
SH-60B's Avatar
SH-60B
Bill
There's a dent?
To Space to remove front springs
