Engine stumbles/hesitation on heavy acceleration
Inline fuel filter is new.
I thought fuel filter was clogged so I checked the filter and it's fine.
Until I hit 3800 RPM car runs fine and shifts fine.
Checked timing and it's 14/35. Maybe I thought it was too much vacuum advance and ran it without the vacuum advance and still same result.
Could this also be related to fuel starvation because I'm thinking ignition problem will show at any heavy acceleration, not just near 4K rpm.
I'm hoping it's not transmission (M21) problem.
Any ideas?
Thanks.
Perhaps, it's too tight for rushing air to overcome the airdoor spring? Could this cause momentary shudder/hesitation/slight bog on heavy acceleration and WOT?
Maybe I should try loosening the tension on the airdoor spring?
Could be just the carb is dirty and needs a good cleaning.
Have you done a tune up lately in may past experience the points needed adjustment about every 10,000 miles on a dwell meter and replaced just about as often.
One of the things that happened on my 1972 El Camino was the distributor got worn out went bad and I had to replace the whole unit at about 90,000 miles. After I installed a new distributor unit the hesitation went away. It was so sloppy I could not get the dwell to set right on it because it was inconsitant.
Thanks for the reply. Spent 2 hours tinkering with the air valve springs and test runs.
Current default spring tension was 3/4 turns clockwise from where there's no spring tension.
I increased clockwise 1/8 turn from current 3/4 turn and it still bogged and stumbled around 4K. Went another 1/8 turn clockwise and it still bogged and spring tension was so tight from there, the car ran like crap and very stiff.
Went other way 2/4 turn from default 3/4 turns, still the same.
I went far as 1/4 turn from where spring has no tension and at 1/4 turn, air door was very easy to open but closed properly without sticking. Anything under this, air door got stuck in down position.
This is where I had no issue with bogging at 4K RPM or over.
I'm having little difficulty understanding why there's minimal spring tension, my car does not stumble or sputter at 4K. Isn't my air valve opening too early if spring is too loose and leaning the fuel too early?
This carb is commercial rebuilt jet p stage 2 800 cfm qjet. I bought it way before I found out Lars do rebuilds.
Bottom line is I was sweating a little thinking my tranny was slipping because it felt like it.
