Where is this coolant coming from?
Old May 25, 2013 | 03:48 PM
Joebrick's Avatar
Joebrick
Default Where is this coolant coming from?
I have been dealing with a coolant "weep" for a couple years that is so small it dries up when I drive but it bugs the daylights out of me and I can't pinpoint it to fix it.
Location is drivers side head, just below the valve cover and above exhaust manifold connection. No.7 plug location and just below the valve cover bolt. Green spot right on the casting ridge. It never seems to turn into anything but always comes back after the car sits.
My intake seems dry up above at the joint. Anybody see or hear of this before? (73 L82)
Old May 25, 2013 | 03:53 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
if I read right, back of mani, top of mani?
where the coolant crossover is?
most mani bolts need sealant for oil weep, I can't remember if the one over 7 goes into coolant?
Old May 25, 2013 | 03:59 PM
scottw's Avatar
scottw
May have to pull the manifold and reseat it. I think 7 goes into oil but it is worth a try to take it out, put sealant on it and retorque the bolts down. That would be easier than taking the entire thing off.
Any issues with a vacuum leak?
Old May 25, 2013 | 04:02 PM
rene040269's Avatar
rene040269
I do hope that i am wrong but could be a small crack in the head.
Old May 25, 2013 | 04:20 PM
Joebrick's Avatar
Joebrick
I do only have 15" at idle with all intake manifold connections isolated....which has always seemed low. The weep seems to be above the exhaust manifold but below the valve cover. ...under the back valve cover bolt hole location.
Old May 25, 2013 | 04:27 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
oh, exhaust side.
is your coolant temp sensor on that side?
head bolts also need sealer
one thing about coolant, it can be blown back and collect a long way from the leak.
lets see, freeze plug?
Old May 25, 2013 | 04:42 PM
Rich's'78's Avatar
Rich's'78
Default different opinion
I think you have 2 unrelated issues.
The small coolant leak: add some sealant pellets (GM sells them, as do Prestone and Barr's). I have read that GM added it at the factory for some cars. It will not plug your heater core or rad. I have used it on several cars in the past and never had a problem (I prefer to grind them up in coolant and add to the rad as a slurry, then drive the car right away.
The manifold vacuum does seem low, but that is probably just a leak in one of the vac hoses or attachments. Best to find and fix that. I have an L-82 clone and get 17" - 18" at idle. My old DD with an LG4 had 20" at idle because of the mild factory cam.
Old May 25, 2013 | 04:59 PM
Paul L's Avatar
Paul L
Can't hurt and worth a try. Those pellets were used quite effectively on the Cadillac Northstar engine.
Old May 25, 2013 | 09:03 PM
Joebrick's Avatar
Joebrick
Thanks Paul 74. Found these same pellets sold as the Bars leaks brand and they recommend adding six on the package. Worth a try.
Old May 26, 2013 | 08:20 AM
MalibuVLX's Avatar
MalibuVLX
Head bolts go through to coolant valleys. Make sure they have sealant on them. I had the same problem once and one of my bolts had sealant, but just not enough. One tube of RTV and she was fixed.
I was thinking freeze plug too, but if it is that high, I would count that out. Good luck.
Old May 26, 2013 | 09:42 AM
Bagmup's Avatar
Bagmup
Old May 26, 2013 | 11:22 AM
scottyp99's Avatar
scottyp99
Originally Posted by Bagmup
Scott
Old May 26, 2013 | 12:21 PM
MalibuVLX's Avatar
MalibuVLX
I guess that was directed to me? So other than Locktite thread sealant and RTV? What does the all mightly "S.A." say???
Mine is still not leaking and that was 5 years ago.
I have been told that "NO" is a sentence, but you did not provide any further insight.
Old May 26, 2013 | 06:21 PM
Bagmup's Avatar
Bagmup
So you used a proper thread sealant on the threads? That's cool then, i thought you must have stuck that goopy crap on the threads as well...just havin' some fun
To Where is this coolant coming from?
