Pressure In Cooling System?
Old May 25, 2013 | 06:18 PM
Lt1er's Avatar
Lt1er
Default Pressure In Cooling System?
The motor seems to run fine and no anti-freeze smell. But I can fire it up cold and let it run 10 seconds, shut it off and I have pressure under my radiator cap.
I drove it and it never got hot and it over flowed my expansion tank.
I've heard of some test to see if you have combustion gasses in the anti-freeze.
I assume that I have blown head gasket?
Old May 25, 2013 | 06:23 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
think there is a litmus paper that you dip in the rad to see if it changes color to "bad" news.
it is curious about the pressure.
seems ole school was looking for bubbles in the coolant at the neck of the filler.
good luck
Old May 25, 2013 | 08:10 PM
TimAT's Avatar
TimAT
Take the radiator cap off when it's cold, start it and let it warm up. If it blows bubbles in the radiator, it's not good. IF the head gasket is leaking, it'll have a steady stream of bubbles.
Old May 26, 2013 | 02:54 PM
john 72-04's Avatar
john 72-04
If you have a radiator pressure tester put it on in place of the radiator cap. Start the engine and see how rapidly it builds pressure. It should build it gradually to the rated pressure of your cooling system. If it builds it rapidly or exceeds the system design pressure you have exhaust gases entering your cooling system. Time to pull heads.
Old May 26, 2013 | 06:31 PM
Lt1er's Avatar
Lt1er
Thanks, I will find a shop that has one. I might check auto zone and see if they have one.
Today I went by summit racing and bought FelPro MLS head gaskets 1142.026
They compress to .026
I was also going to straight edge the heads
To Pressure In Cooling System?
