Did I Torque Enough?
I cleaned like a mad man, used high temp RTV in the correct area as the GM manual says to, installed the seal in the right direction (lip to front) with an off-set of 3/8", etc., lubed the seals a little with oil on the crank side as recommended, even waited a couple of days before I put oil back in the engine.
I'm wondering if I didn't torque the cap bolts enough...first time I did the job, and the torque chart from the GM manual can be unclear...says 75lbs, but outer bolts on engines with 4 bolt caps 65lbs. I split the difference and went with 70. Rechecked a couple of times before the pan went back on. Did I go wrong here?
Here's an older pic with some high talent drawing to show you what I mean, green shows where I see a bit of oil (not enough to drip but it's there, and only driver's side):
Also you figured the GM torque specs were not clear so you made up your own.
No oil at all down the back of the pan, dry as a bone, can see it clearly on the lift. This is where it leaked before, and no longer does.
I know there's the cam galley plug back in there that could in theory show itself through the seam at this location.
Will have another look and see if I can determine if it is gear oil, but I'm fairly certain it isn't.
I've read so many different torque specs for the cap, 65, 70, 75, 80, that I chose 70. Seemed like a safe choice.
cap is down.
them seals are tricky to get right.
i am not saying you did not get it right.
just that the torque is not the issue.
Sometimes it's tough to nail down an oil leak, especially when the oil is clean and the block has good paint on it still. The oil becomes near invisible.
The reason I go to rear seal in my head is because of course it is the only one I can't see, other than the cam galley, I will have another look. Car has come a long way since April though, happy otherwise.
Scott
In Ford's F-150's, (1986-1996), with the 5 speed manual transmissions (Mazda-made, believe it or not), there is a rubber plug or dohickey up on the top side of the trans. It degrades, and allows a small leak to run down the side of the trans, about mid-way back (I realize your leak is near the front of the trans, but bear with me).
It was slow, and required a top up of ATF only every 6 months (yup, those Mazda manual gearboxes take ATF). But those who failed to add oil eventually had to buy/rebuild a transmission. It only leaked when in use, so the "spotting" on the driveway seemed insignificant.
I don't know the answer to this, but is the ANY chance it's escaping from the top of the trans? Like from around the shifter/linkages, or from a cracked casting?
Just tryin' to help.
) is that you have developed a leak at one of the 3 pipe plugs on the back face of the block (oil gallery hole block-off plugs). They are sealed at the factory--but the car is 40 years old. To see if that is the problem you will have to remove the lower inspection cover, put some flourescent dye check in the oil, use the little penlight black-light you get in the dye check kit, and try to peek up into the crack between the bell housing and the engine block.I had one leak on me AFTER I made a transmission change.
Then, I had to disconnect the tranny again to seal it back up.
Snapped a couple of pics. Same thing as before - pan and flywheel totally dry, just shows itself at the seam between the block and bellhousing and the driver's side corner and runs down from there. Was able to stick a finger up around the crank itself and it is very dry. The little "ledge" at the back of the block up inside is a dirty place, and it might be coming from there, 7T1. Note the blackish area to the left of my green line inside the bellhousing is just ancient grime, not oil.
One to show how dry everything around the pan lip and crank really is - no traces of oil at all (it leaked badly here before I replaced the rear main and pan gasket):
Only place on the inspection cover where oil is present - driver's side edge against bellhousing as shown in first pic:
