75 Stingray
Old May 26, 2013 | 04:05 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default 75 Stingray
Can anyone tell me what is the normal water temp on a corvette. I have a 96-00 crate vortec 350 and running around 200 to 205. I have a aluminum radiator and two electric fans which are set to run all the time for now. Is this a normal temp?
Old May 26, 2013 | 05:15 PM
iokepakai's Avatar
iokepakai
My warmed over L48 stays between 180-200f.I have an aluminum radiator stock mechanical fan.Shroud is in place and so is the lower air dam.Does the lower hose have the spring in there? Also check timing and maybe try full manifold vacuum timing instead of ported.My initial is at 12 deg and with full manifold vacuum it's close to 24deg at idle.I'm running a Crane Billet dist so timing adjustments are simple.Read the posts on timing,careful not to cause pinging at cruise and WOT...
Old May 26, 2013 | 09:57 PM
jnealg's Avatar
jnealg
While I wouldn't worry about 205 if it was stable and didn't rise, mine runs about 195-200 with al rad and stock clutch fan.
Assuming the system is clean and flushed, has no air in it and there are no other issues, a lower tstat would be cheap and easy to try. A least you wouldn't have much investment in eliminating it.
Check for weeping at the pump while your there but it's likely you already have or would at least have noticed already.
Old May 27, 2013 | 08:22 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Old May 27, 2013 | 12:15 PM
scottw's Avatar
scottw
What t-stat do you have? If you want cooler temps, go with a 170-185 t-stat. My old engine ran at 200-205. My new ZZ4 runs at 180-190.
Old May 27, 2013 | 02:33 PM
Alan 71's Avatar
Alan 71
Hi Rogerl,
I realize you changed the fan, but do you have any sort of shroud around the fans; and are the seals still around the radiator?
They need to be in place so the fans draw the air THROUGH the radiator and not around it. That's what drops the temperature of the engine coolant.
Regards,
Alan
Old May 27, 2013 | 02:49 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default Rad
No car didn't come with shroud I guess maybe I can find one.
Old May 28, 2013 | 02:36 PM
sfrank2886's Avatar
sfrank2886
You should be running below 200. I have a crate 330 horse with aluminum radiator and direct drive flex fan. Runs like 180 to 190. As soon as I put the new rad on it, it cooled right down with not very good seal around rad. Replace your thermostat to a 185 if you have not already. What type of fans are you running?
Old May 28, 2013 | 03:25 PM
dochorsepower's Avatar
dochorsepower
I agree with Alan, shrouds, seals and lower air dam. I have a 160 t-stat and it runs 160 all the time except maybe pulling up a long, steep hill on a 95 degree day, then it gets up to 180.
Old May 28, 2013 | 05:45 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default Rad
Not sure brand for fan two 16 inch electric. Does shroud make that much difference? I will try lower thermostat.
Old May 28, 2013 | 05:58 PM
82 beerhunter's Avatar
82 beerhunter
just a question most vortec engines had serpent belt systems are you still running this or did you go back to v belts? your water pump could be turning backwards killing the flow?
Old May 28, 2013 | 08:22 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default 75 stingray
Good question, when I got car it has v belts. So I need to look at pump. Thanks
To 75 Stingray
