Headlights
Old May 27, 2013 | 01:34 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default Headlights
Previously my 75 the headlights would not come up, so today I started working on them, I got them working but I shut car off they go up and down. On the vacuum line it is missing the little white stop valve could this be why it goes up and down when I shut engine off?
Old May 27, 2013 | 02:26 PM
Alan 71's Avatar
Alan 71
Hi Rogerl,
Headlights Working.... NICE!
The little white plastic item is a filter. I believe there should also be a gray metal 'one direction' valve. It should have one large hose going in and a large and small hose coming out.
That could be the cause of your trouble, or it could be a relay problem.
Regards,
Alan
Old May 27, 2013 | 04:05 PM
hugie82's Avatar
hugie82
My headlights also do that ( only work while the engine is running) I traced it back to my vacuum holding tank (coffee can) . It has tiny rust holes that bleed off the vacuum in seconds.
To Headlights
