#3 hole dead, upon inspection exhaust rocker maybe 1/4 " travel ordered thumper cam kit w springs double roller chain and gears. Motor is stock with 4 speed any problems ahead? I hope normal cam change procedure with radiator and condenser removal?
Normal SBC cam change will do the job. Correct tool to remove and install the balancer, use a good 2 or 3 jaw puller to remove the crank gear, install the new crank gear. I heat them in the oven at 350* for about 30 minutes and use a short pipe to seat it. And work fast so it stays hot. Goes on much easier when hot. Look at the seal area on the balancer- if there's a groove from seal wear, put a speedi-sleeve on it unless you have another reason to replace it.
plan to get more friendly with your local gas station, plan on your headlight doors working different, I took the almost new thumper out of mine and went with a factory 350 hp version, everything back to normal and works better with my 2004R swap
Which one, the L46 cam or the L79 cam? Not a whole lot of difference, but still........
Because why???? not that wild of a cam should not be a problem with vacuum
Reason: spelling
Sh** putting in
Thumpr Hydraulic Flat Tappet Camshaft Complete Kit
Lift .479"/.465"
Duration 279/297
RPM Range 2000 to 5800
View this item
249-CL12-600-4
3896962 but its duplicated by several mfg's . my version came from Howards with the 5 year no fault waranty, crane cam-savers and other parts bought seperately
Scott
True, but the L79 cam has a ground in advance of 4 degrees; the L46 cam doesn't. But, if you advance the L46 cam with the crank gear or by using offset bushings in the cam gear, they're nearly identical.
