Help me understand these vacuum readings
Old May 29, 2013 | 07:42 PM
my 76 ray's Avatar
my 76 ray
Default Help me understand these vacuum readings
Went to an autocross on Monday and my engine started running rough. It ran rough all the way home and when I shut off the lights they didn't close so I figured I had a vacuum leak. Today I put the vacuum gauge to a manifold port on the carb and it was reading 12" of vacuum. I do have a bigger cam but that's low for it. Now comes the strange part. I started to disconnect vacuum lines to find out where I was losing it and when I disconnected the line that goes to the PCV valve and the charcoal canister, the vacuum jumped to 17" with the line open. I put my thumb over the line and the vacuum fell to 15". I reconnected the line and tightened it and the vacuum is still 15" but now the engine is running smooth and the headlight doors open and close.
I don't understand why the vacuum would rise with a line disconnected. Can anybody explain it?
Old May 29, 2013 | 09:26 PM
my 76 ray's Avatar
my 76 ray
OK, I have a theory. If the two ports are connected inside the carb, then the large amount of air being sucked into the open line could create a venturi effect on the port with the vacuum gauge connected to it. That would increase the vacuum reading on that port and in turn on the vacuum gauge.
