Transmission
Old May 29, 2013 | 09:17 AM
czardali's Avatar
czardali
Default Transmission
I put my car in reverse the car makes this dramatic jolt. It's like a snap back crack that is loud. The transmission was rebuilt two years ago. The frequency is on and off but mainly when low on fuel/subtle incline.
Not sure if its related but im leakin oil and oil pressure gauge is jacked up. Both are being fixed this weekend.
thanks for the input in advance.
Old May 29, 2013 | 10:44 AM
7T1vette's Avatar
7T1vette
Two issues may be present: 1) your idle speed is excessively high (above 700 rpm); and 2) the rubber cushions on the differential mounts could be shot.
Old May 29, 2013 | 11:13 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
When the factory chin bushings/cushions on the differential dry rot, the subsequent loss of stability causes ugly noises there. A common source to the clunking problem on these suspensions.
Old May 29, 2013 | 11:14 AM
OMF's Avatar
OMF
To go along with the above...U-joints could be shot as well. there are 6 of them....check them all
Old May 29, 2013 | 12:07 PM
sstopczy's Avatar
sstopczy
To Transmission
