Spreader bar Install
Old Jun 11, 2013 | 05:12 PM
PeteZO6's Avatar
PeteZO6
Default Doesn't Anybody RTFM
I lurked here when I first saw the thread as I was waiting for my Speed Direct Spreader Bar to arrive and I wondered what I was in for.
Having installed mine yesterday, I can say a lot of folks on this forum do not bother to read the instructions that come with the device.
Notice no where does it say to raise the vehicle. I tried that and it's not a good idea. I raised the car when the control arm cross shaft followed the nuts toward the center of the car. Fearing that they would come off the end of the studs when the nuts were removed. The cross shafts stopped moving after a couple of inches of movement.
The problem with raising the car is when you put it back on the ground, you have to drive it to get the frame back to it's natural state. You can't do that with the spreader bar in place because it will biind everything up. So I got the brackets aligned properly for fore and aft placement so the bar didn't touch the fan or the p/s pulley. Then I was able to remove the bar by shortening it. Once the bar was removed, I drove around the block to settle the suspension, and finally I put the bar back in.
No where does it say zero preload, in fact, exactly the opposite. See instruction #4. It wants one half to one full turn of preload on the bar. Hey, I'm just repeating the maufacturer here.
I made what I think is a significant improvment to the product. The grade 5 bolts which are used to attach the bar ends to the brackets are threaded all most all the way to the head - the shank or unthreaded part is very short. The result is that part of the bar end and the second piece of bracket the bolt goes through, seat on threads, not the shank. I found some grade 8 bolts that have shanks just long enough to pass through both bracket tabs. The only downside to these is the nuts are lock nuts, like the valve adjusting nuts. That meant tightening the nuts was a very slow and laborous task.
I think (I hope) my mod is an improvement although the amount of stress on those bolts and the bar itself shouldn't be that great.
So OP, if you haven't already read the instructions, give them a once or twice over and have fun with the installation.
Pete
Old Jun 11, 2013 | 06:57 PM
billcarson's Avatar
billcarson
pete z06 i see what you mean as i have just installed the same spreader bar.you deserve royalties from the company going forward.thanks for the tip.
Old Jun 11, 2013 | 07:02 PM
PeteZO6's Avatar
PeteZO6
Thanks Bill Carson! (I just saw those very words on another thread.)
Pete
Old Jun 11, 2013 | 07:37 PM
MIKE80's Avatar
MIKE80
I also preloaded my VBP spreader bar when I installed it with the vette on the ground.
Old Jun 11, 2013 | 07:47 PM
oldalaskaman's Avatar
oldalaskaman
x2
Old Jun 12, 2013 | 07:49 AM
scrappy76's Avatar
scrappy76
I had planned to install mine last weekend, but I had forgotten the p/o had cut the front bolt on the passengerside to get the fan shroud out easier. So I am ordering a new bolt this week. Then I have to replace. Hopefully will be able to install the weekend of the 22nd. Not in a big hurry, weather sucks anyways.
Old Jun 12, 2013 | 10:01 AM
SuperBuickGuy's Avatar
SuperBuickGuy
Is it pre-load to push the frame rails back to where they were when the car left the factory? The whole point of the spreader bar is to double the strength of the top of the a-arm because the frame will flex there. I used a t-square before I put the bar on to check where the frame was in relation and was pretty amazed at how far inboard it was at rest and how far it moved just by jacking the car up and allowing the suspension to drop...
when you do put it on the car, it's best to check to see how far it's flexed - and align it if necessary after you put the spreader in place.
Old Jun 12, 2013 | 10:22 AM
MIKE80's Avatar
MIKE80
I also probably have less flex than a stock chassis does. When I had my frame out I did all continuous welds, added gussets, boxed the front of the frame, installed VBP front monoleaf with their offset A arms (VBP Performance Plus full kit), large swaybar, poly bushings, and poly engine mounts. I did have it aligned after the spreader bar install.
Old Jun 12, 2013 | 06:13 PM
gcusmano74's Avatar
gcusmano74
Curious thing about step 4 in that spreader bar instruction sheet. It says to put in some preload on the bar, but not in which direction.
Do you spread the towers apart, or pull them together?
Old Jun 12, 2013 | 06:28 PM
PeteZO6's Avatar
PeteZO6
Good catch. But since vehicle weight and pounding of the suspension tend to bend the upper arm supports together, the preload should be to spread the supports apart. It is a Spreader Bar, after all.
Pete
Old Jun 12, 2013 | 08:02 PM
Haggisbash's Avatar
Haggisbash
Did anyone ever come up with a spreader system for a std SBC car still fitted with the mech radiator fan?
Old Jun 12, 2013 | 08:06 PM
billcarson's Avatar
billcarson
yes read post # 21.that's the one.
Old Jun 12, 2013 | 08:21 PM
  #33
aussiejohn's Avatar
aussiejohn
Default Correct factory measurement???
G'day,
I have all of the parts to make a spreader bar for some time now, but have never gotten around to fitting it. However, I have asked the question previously about the stock factory distance between the two shock towers and have received replies from Forum members that the correct measurement is 26+3/8".
So, it might pay you to adjust your spreader bar until you reach this dimension. Comment on the above will be appreciated.
Regards from Down Under.
aussiejohn
Old Jun 12, 2013 | 08:31 PM
  #34
Super6's Avatar
Super6
I'm sitting here with the VB&P non-welded spreader bar in a box next to me. I'm not arguing or taking sides, just reporting as was done in Post 21. The instructions from VB&P say "You may need to lift the frame of the car slightly so the cross shafts do not try to slide off the studs. Once the bar is installed, you can pre-load it slightly outwards."
Seems that they mean to pre-load the bar after the jack is off the frame, although it doesn't specifically say it.
I have a lot going on with my car right now, but when I get to the spreader bar, I'll be having fun putting it on a big block with an engine-driven fan, exactly the application the kit isn't designed for.
Old Jun 12, 2013 | 09:19 PM
  #35
jyounane's Avatar
jyounane
Originally Posted by aussiejohn
G'day,
aussiejohn
Hi John,
If you set to factory then you'll need another wheel alignment. Chances are, your existing alignment will be based on the settled distance between towers which is now less than factory.
BTW, any interest in making/selling me a kit for my 69? US Vendors + Shipping make these spreader bars very expensive!
Just PM me.
Joe
Old Jun 12, 2013 | 10:54 PM
  #36
oldalaskaman
there is an excellent write up from a member here who made his own from materials purchased at a hardware store, total cash , bout $40. you can also buy all the materials on line. His looked as good as some and better than others
Old Jun 24, 2013 | 12:18 PM
  #37
scrappy76's Avatar
scrappy76
Update.
I replaced the a-arm bolt the was too short and will be installing the spreader bar this week.
To Spreader bar Install
Old Jun 24, 2013 | 03:30 PM
  #38
mrvette's Avatar
mrvette
Originally Posted by hugie82
Question, does anyone feel a difference in handling with the spreader bar??? I've asked others and they said barely and I think its because they spent money! So they felt compelled to say that
They have crappy stock tires/wheel sizes on there.....put some C4 rims on there and you WILL notice a HUGE DIFFERENCE.......
car corners like Lord intended....
of course other mods also help....but the difference with good rubber is night and day....
Old Jun 25, 2013 | 04:20 PM
  #39
jb78L-82's Avatar
jb78L-82
Speed direct bar on my 78 with the mechanical stock fan and shrouding. As others have stated-made a gigantic difference. I installed my bar AFTER I had put on 17 inch rims with 255/60/17 ZR tires years before. Every C3 can benefit from a spreader bar due to the frame flex. Best bang for the buck!
Old Jun 26, 2013 | 05:16 PM
  #40
hugie82's Avatar
hugie82
I guess BF Goodrich isn't gonna cut it
Thanks for the honest info
