Spreader bar Install
Old Jun 26, 2013 | 05:43 PM
  #41
jb78L-82's Avatar
jb78L-82
I had BFG 255/60/ 15's for years before the current Kuhmo summer only 255/45/17 ZR's-Holy smokes- no comparison!!!
Old Jun 26, 2013 | 07:10 PM
  #42
Frankenvette's Avatar
Frankenvette
Same here. Love the Kuhmo's.
Old Jun 29, 2013 | 10:20 AM
  #43
gkull's Avatar
gkull
Originally Posted by 7t2vette
Yes, you can install the bar that way without any issues. Just make sure to put the proper shims back into place if any fall out.
The bar needs to be installed with the car on the ground; you adjust it so it is snug, but not tight. You should be able to move the bar with relative ease when finished. If you tighten the bar too much, you will be changing the static alignment numbers of the car.
I pondered this also. IMO You are trying to eliminate flex. I already have solid motor mounts and welded gussets. I had to repair my 79 lower frame because it cracked where the lower A-Arm bolts to the frame.
So it is true that you would need a new front end alignment if you spread the distance. But I lifted my car front end and installed the bar just hand tight and drove right to the alignment shop. My camber change was very minor if any. I think the real bending forces are when you go into a max "G" turn and really loading the front tire on one side
Old Jul 2, 2013 | 02:32 PM
  #44
scrappy76's Avatar
scrappy76
What do you mean you lifted your front end, then installed the bar? You mean your wheels were off the ground when you installed it ?
Interesting. Everyone else says for the car to be sitting on the ground as if your getting ready to drive it. Confusing. I replaced that bolt I needed to, so I am ready to install my bar, actually been trying to for the last week, too many honey doo's to do.
Old Jul 2, 2013 | 04:45 PM
  #45
gkull's Avatar
gkull
Easy. IMO - Lets say that weight on the front end bends the top of a-arms in. Why would you want to then install a spreader bar to hold it in the sagging position.
So with the front tires off the ground I installed the spreader bar and I ran the rod out hand tight and locked the jam nuts. I then drove straight to the tire shop and had new front tires installed and had them put it on the alignment rack.
Old Jul 3, 2013 | 10:33 AM
  #46
scrappy76's Avatar
scrappy76
I think I am going to install with the the car on the ground. Then measure between the bar mounting points. I will raise the car untill the wheels are just leaving the ground. Then take a measurement. Depending on the difference, I will most likely split it and install at that point. You have to keep in mind that you are possibly causing it to sag the other way. Not sure if I am using the correct terminology, but I will assume you understand what I am saying.
Old Jul 3, 2013 | 07:51 PM
  #47
aussiejohn's Avatar
aussiejohn
Default Post #33
Scrappy,
Please check post #33, then check a Factory Service Manual to find the distance between the top of the dampers that the FACTORY designed into the cars, and lock your spreader bar at that measurement. Then take it to the alignment shop.
Regards from Down Under.
aussiejohn
Old Jul 4, 2013 | 09:34 AM
  #48
oldalaskaman's Avatar
oldalaskaman
excellent advice
Old Jul 4, 2013 | 09:45 AM
  #49
'75's Avatar
'75
Originally Posted by aussiejohn
Scrappy,
aussiejohn
Can someone post that measurement, and is it virtually the same for all C3's?
Old Jul 13, 2013 | 08:04 AM
  #50
Tim81's Avatar
Tim81
Just installed the spreader bar from Speed Direct and I am confused with the instructions on how to set the pre-load. If I tighten the lock nut on one side there is noway that I can turn the bar to set pre-load. Can somebody tell me what I'm doing wrong?
Old Jul 13, 2013 | 10:18 AM
  #51
billcarson's Avatar
billcarson
i just did this job with the same bar and you rotate the bar to set the load.one thread is chinese and if you lock one side the bar will not turn.you were supposed to run the heim bolts approx evenly in on both sides before setting it in place.good luck and it is worth the effort.also have the car on the ground with the suspension settled before you adjust it.
Old Jul 13, 2013 | 10:30 AM
  #52
Mid-Years Forever!'s Avatar
Mid-Years Forever!
Old Jul 14, 2013 | 01:32 AM
  #53
scrappy76's Avatar
scrappy76
I just installed mine. pretty easy to install, even on a big block swapped in bette with electric fan. I installed both ends with a jack under each coil bucket to relieve pressure on bolts. Then I lifted it up in the middle of the crossmember just by a couple cranks, about 1 inch. I installed the bar and adjusted where the heim threads were even. I turned the bar till I felt the slightest pressure. Locked down the nuts, then lowered the car. Took for a drive down a back road and I did feel a difference in the curves of the road, felt tighter, with a little less roll. Ver happy. Will post pic later.
On to my next mod, removable rear window.
Old Jul 14, 2013 | 10:31 AM
  #54
redvetracr's Avatar
redvetracr
the last time my car was on an alignment rack the guy doing the alignment showed me how the camber changed as we expanded the spreader bar, snug is all it needs.
