pump
Old May 31, 2013 | 11:43 AM
rays699's Avatar
rays699
Default pump
how to torque down the nut on a power streeing pump and hold down the pulley from trunning on a 69 bb vette
Old May 31, 2013 | 11:48 AM
morleyz's Avatar
morleyz
There may be better ways, but I use strap wrenches anytime I need to tighten down a pulley.
Old May 31, 2013 | 12:24 PM
TimAT's Avatar
TimAT
If you don't have a strap wrench, wrap the drive belt around the pulley, wind a pry bar up in it and go. Won't do the belt any good, but you can get the nut tight.
Old May 31, 2013 | 01:07 PM
oldalaskaman's Avatar
oldalaskaman
if you have room and an impact, use it, works for removing alt. pulleys also
Old Jun 1, 2013 | 09:32 AM
rays699's Avatar
rays699
no room for a impact, because of the fan shroud. I will try the strap wrench, thanks. one more thing I am putting on a power streeing box from borgeson, the hoses are a bitch, no room for a wrench at the box, because of the hearders the wrench is to long, did anyone use crowfoot, to get to the nuts. and do you bottom out the inserts in the box, or use the hoses to get them all the way in ? thanks ray
To pump
