Ignition wires(original) Help
Old Jun 1, 2013 | 05:28 PM
blk406's Avatar
blk406
Default Ignition wires(original) Help
Ok, this is probably a really stupid question but I have to ask. Where do the little ground wires on each ignition wire screw down to on the cap side? I figured out the spark plug side screws down to each valve cover screw. I just bought the correct date coded wires for the car that had the wrong wires on it. Thanks in advance.
Old Jun 1, 2013 | 05:30 PM
TimAT's Avatar
TimAT
IIRC, (I haven't had that type wires in forever), the distributor end all grounded to the shielding around the distributor.
Old Jun 1, 2013 | 06:21 PM
Alan 71's Avatar
Alan 71
Hi blk,
I believe the stud that the braided wire mesh over the spark plug wires grounds to is part of the distributor shield supports.
Regards,
Alan
Old Jun 1, 2013 | 09:13 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Old Jun 2, 2013 | 09:05 AM
blk406's Avatar
blk406
Thanks guys, I appreciate it. Wires are on and they look much better. Thanks.
To Ignition wires(original) Help
