Replaced my stat but ??
Old Jun 1, 2013 | 07:42 PM
redwhitekat's Avatar
redwhitekat
Default Replaced my stat but ??
So I was in there today on my 74 l82 replacing gaskets on my new water pump with some rtv gasket maker replaced my pulleys to alluminum. Then replaced my stat with the stant 180. When I took the old one out I was surprised it was a 160 stat. Is this normal to run a 160 stat. I thought the original was 190 and I was doing a good thing by going to a 180.
What temperature stats do you guys have
Old Jun 1, 2013 | 07:54 PM
7t9l82's Avatar
7t9l82
i run 160. others will tell you "the factory ran a 190" or other such stuff. few really remember just how "well" these cars ran when new. running a cooler thermostat will cause absolutely no problem, and if you have an automatic transmission it will help that out too.
Old Jun 1, 2013 | 07:58 PM
redwhitekat
I always thought these engines had to run at a certain temperature. 160 seemed a bit low but what do I know. My 04 Landrover which these truck are natorious for overheating had a 190 stat which would run in the 205 to 215
Put in a 180 stat now it runs 194 to 200 all the time
Old Jun 1, 2013 | 08:04 PM
7t9l82's Avatar
7t9l82
30 degrees less temperature won't hurt a thing, a 190 in the winter In Minnesota probably never opened the thermostat.
Old Jun 1, 2013 | 08:23 PM
TimAT's Avatar
TimAT
That "certain temperature" thing is 100% for emissions. Not a thing to do with performance.
Old Jun 1, 2013 | 08:54 PM
redwhitekat
So do you guys suggest I put in a 160 ???
Old Jun 1, 2013 | 09:04 PM
johnt365's Avatar
johnt365
This is an interesting thread. I am curious, what was your temp gauge reading while running the 160* tstat?
Old Jun 1, 2013 | 09:10 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
some one before you went with 160. not GM
as mentioned, what was it running and why are you in the coolant system?
redwhitekat
Well according to my stock gage just a touch under 200 now it's just at 200 sometimes a bit less
Old Jun 1, 2013 | 09:12 PM
redwhitekat
I was removing the water pump to put some rtv gasket maker as it was leaking a bit
Old Jun 1, 2013 | 09:23 PM
johnt365's Avatar
johnt365
I use a Stant 180* like the one you bought. I remember drilling a couple holes in it, not sure if it matters much.
The gauge on my 74 reads 180 at operating temperature. I have also used a laser thermometer to take readings at the tstat housing and at the radiator intake and its within a couple of degrees of 180.
Do you have access too a IR/laser that you could verify your operating temp against your gauge?
Old Jun 1, 2013 | 09:27 PM
redwhitekat
I do that's a good idea. I'm sure according to the gage it's fine but is runing something cooler like a 160 better and safer for the engine
Old Jun 1, 2013 | 09:39 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
hmm, I doubt the engine will run 160.
if it did, I will go with the opinion, more wear.
my personal idea is 180 would be good.
Old Jun 1, 2013 | 10:41 PM
BKbroiler's Avatar
BKbroiler
Back in the days before emissions controls, let's say prior to 1968, when the factory had no concern for emissions, and would select a stat temperature purely for best running, engine life etc. type reasons, what temperature did they select? I think it was 180.
Old Jun 1, 2013 | 10:44 PM
redwhitekat
Interesting only a car owner pre 1970 can answer that if they remember what stat was original
Old Jun 1, 2013 | 10:45 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
I do not run a stat. I have a restricter plate in it. But I also live in South Florida.
Old Jun 1, 2013 | 10:59 PM
Mike Ward's Avatar
Mike Ward
Then it won't matter one bit whether you use a 160, 180 or 190.
Pre-emissions Corvettes came factory equipped with a 180.
To Replaced my stat but ??
Old Jun 2, 2013 | 12:25 AM
my 76 ray's Avatar
my 76 ray
The 160, 180 or 190 is the temperature at which the thermostat opens. If you're running at 200 then that is the capability of your system with the thermostat open. The only difference should be that it will get to 180 a bit faster with the 180 t-stat than with the 160 t-stat.
Old Jun 2, 2013 | 02:41 PM
7T1vette's Avatar
7T1vette
If your engine is computer controlled, it may need to have a 195 degree stat in it. The ECM's tend to NEED an operating temp of over 190F for it to switch to normal operating mode. Otherwise, they just operate to a 'default' program routine.
If you don't have an ECM controlling the engine, you can install any stat you want. It just depends on what minimum operating temp you want for the engine and how fast you want it to warm up. The Chevy engineers wanted the V8 engines to run at 180F (before the initiation of EPA regulations).
Old Jun 2, 2013 | 04:48 PM
7t9l82's Avatar
7t9l82
it isn't so much the computer controlled cars " need" 195 degrees, it is what the manufacturers want to keep their emissions target. every new car i have had since 1984 very quickly got 160 degree thermostats in them , all went over 300k miles and never burned a drop of oil. the transmissions never had an issue either. i say it is all
