Speedo 7mph off
Old Jun 2, 2013 | 08:53 PM
alswagg's Avatar
alswagg
Default Speedo 7mph off
I finally checked the speedo today. I knew it was off last summer as I recieved a warning ticket. I just did not know how much it was off. At 60 mph on GPS the speedo needle reads 52-53. I believe I need at least on less tooth on the speedo gear maybe two. Any ideas??/ Thanks Al
Old Jun 2, 2013 | 09:02 PM
zwede's Avatar
zwede
Check the odometer. If the odo counts the miles correctly you have a speedo that has demagnetized. Only change the speedo gear if the odo is off the same as the speedo.
