72 4 spd thunk noise when shifting
Old Jun 3, 2013 | 10:44 AM
Sully1882's Avatar
Sully1882
Default 72 4 spd thunk noise when shifting
I am finally at a point where I can get my car on the road! When out and driving i notice this... when I let the clutch out, doesn't matter what gear, there is a kinda thunk noise. It feels like it is in the rear of the car. Like something is tilting when it engages. If I am coasting and shift slowly and light it doesn't do it but if I am accelerating and shifting it does happen. The u-joints were inspected and have no play. I am thinking either the cushion for the trans brace or the rear end. What do you guys think and how do I diagnose?
many thanks,
Sully
Old Jun 3, 2013 | 10:50 AM
4 speed's Avatar
4 speed
mine does that to , but only in 1st. or at least I can't hear or feel it in upper gears
Old Jun 3, 2013 | 10:17 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
Default Rear end
It sounds like the cushion that mounts the front of the differential to the frame. Not hard to replace and not expensive, which is somewhat of a rarity.
Old Jun 4, 2013 | 12:08 AM
PeteZO6's Avatar
PeteZO6
Good call While you're there, check the two volts that hold that mount bracket to the diff. housing. If they loosen up, you will hear and feel a clunk as you described.
Pete
Old Jun 4, 2013 | 01:20 AM
jnealg's Avatar
jnealg
Pete
I had one of those bolts missing and the other loose. I also had a bad xmission mount.
Mine would thunk just looking at it.
To 72 4 spd thunk noise when shifting
