Top end build l48
Cam
http://www.jegs.com/i/Comp-Cams/249/CL12-600-4/10002/-1
Heads
http://www.summitracing.com/parts/sum-151124/overview
Intake
www.summitracing.com/parts/edl-2116
So will it be fine running just the heads and intake for a month? Also is that camshaft good?
http://www.summitracing.com/parts/cca-cl12-600-4
Personally, I think that's a pretty big cam paired up with a performer manifold, here's what I'd go with, depending on your diff gear and transmission. (But I'm a cheapskate!!!)
http://www.summitracing.com/parts/su...make/chevrolet
BTW, how do you snap off a valve cover bolt? The torque spec is 3 ft-lbs.!!!!!!
Scott
Scott
Scott
Torque is what throws you back in your seat and what you feel not HP.
The Thumpr cam is tuned to sound good idling and pulling in to the local car show or mcdonalds... its basically a poser cam meant to mimic the sound of a much bigger cam... You will constantly be defending yourself around anyone that's car savvy. t is not designed for performance or to be efficient...performance is secondary to "sounding cool" it reminds me of the fart cans on the ricers. With it, you give up about 3mpg compared to other cams that give you more power .the tight lsa causes much of the gas to go out the tailpipe unburnt. Also the vacuum is poor with it so your power brakes and such won't work well without additional hardware.... just Google it and read about it.... there's a few exceptions like super Buick guy here that seem happy with it but almost all of the reviews are poor and that that arent are bias and don't compare them fairly to a properly set up similar cam intentionally. And you won't find one single review where someone actually swapped a similar sized aftermarket cam for it and liked it.... but you find a few that are the opposite.
Street car = street cam.
Race car = race cam.
Figure out your compression ratio. This will help decide how much duration and overlap you can go with on your cam. Do searches on this forum there is a TON of info on this subject. The K1103 is an old school cam with a slow ramp for valve opening, good for longetivity of the cam not as good for responsive power.
Figure out what you want from a cam. Quick response, low end torque, high end HP, etc. What rpm range are you realistically going to be operating in? For most of us that is 1500 to 5000 rpms. If you want a responsive torqey street motor then stick with lower overlap numbers and less duration would be my recommendation.
Subtract the advertised duration from the duration @ .050 the result is known as hydraulic intensity. Get a number below about 50 and your talking about a cam lobe that is considered high intensity.
Good for response not so good for cam life span on a flat tappet cam. Like this xe262
http://www.compcams.com/v002/Pages/387/XE262H-10.aspx
Broken down into numbers it has an intensity of 44.
The K 1103 has an intensity of 74.
Big difference in how the two operate the valve opening. This would also increase the time in which the intake and exhaust are open at the same time reducing your cylinder pressure and developing less low end torque.
This one is for flat tappet has a bit less intensity than the XE series at 46.
http://www.compcams.com/Company/CC/c...?csid=219&sb=2
Seems most common lobe seperation used that i have noticed is 110 or 112 degrees.
Many things to consider, this only scratching the surface.
Summit dart heads
http://www.summitracing.com/parts/sum-152123
Cam
I want torque. I will be operating in low rpms alot too. Never really over 5000. Also i have an automatic and that cam says it is the highest you can go with stock convertor. You guys think im set to order them?
http://www.speedwaymotors.com/Flo-Te...lug,25118.html
You can read up on what Car Craft thought about these heads here:
http://www.carcraft.com/techarticles...t/viewall.html
I've never used them, so I can't speak from experience, but Speedway Motors has a pretty good reputation, and in the Car Craft test, they made power comparable to the Vortec heads, they're aluminum, 64cc combustion chambers, and you don't need a special intake manifold, valve covers, and rocker arms. Which means you can scare up an old Performer intake on the internet for about 50 bucks. I'm going to be giving them a try when I do the top end on my engine. Like I said, just something to think about........
Here's a link to the head gasket iokepakai is talking about, it's the cheapest I have been able to find it:
http://www.northernautoparts.com/Pro...tModelId=22765
Scott
