horn doesn't work 1980 vette
Old Jun 4, 2013 | 02:15 PM
c3cruzn's Avatar
c3cruzn
Default horn doesn't work 1980 vette
Hi evryone
Hoping someone can help me with this. My horn won't work and it did not when I bought it. Bought all new parts inside the steering wheel and have checked fuses, and horn itself. All the wiring from the horn to the firewall all seems to be in good condition. Test light and screw driver test showed no power under the wheel, any suggestions.
Old Jun 4, 2013 | 10:52 PM
Chicagodogs's Avatar
Chicagodogs
Try shorting the pin that touches the L bracket to ground.
Old Jun 5, 2013 | 12:35 AM
rjoyal's Avatar
rjoyal
the horn circuit on these things is simple, yet weird. (and it appears is standard GM for the time - my 1980 Trans Am has the same circuit and donated the relay.)
power from battery goes to the relay under the dash.
this feeds power to the horns.
the ground wire from the relay goes to the wiring harness at the base of the steering column and then up it.
When you press the horn, you're completing the ground side of the circuit.
From my 1980 service manual:
check the fuse.
check for voltage at horn relay (I had none)
connect a wire from the horn relay black wire to ground. If horns don't work, relay is bad (mine was bad too.)
If horns work, check for loose connection in wiring harness @ steering column (one of the black wires)
I was also missing the pin and the spring inside the steering wheel. Needless to say, troubleshooting it was a pain in the....
here's a link to the service manual:
https://docs.google.com/file/d/0B2Ip...it?usp=sharing
here's a link to the wiring connector:
Old Jun 22, 2013 | 12:14 PM
c3cruzn's Avatar
c3cruzn
Good morning all
I put in all new parts under the horn button and a new horn relay. Works great thanks to all.
Gary
Old Jun 22, 2013 | 11:07 PM
johnnyjaws's Avatar
johnnyjaws
I need to do that too
Old Jan 6, 2015 | 05:25 AM
R6n350GT's Avatar
R6n350GT
check the fuse.
Thank you sooo much for posting that been looking for one. Now i have AIM, Tune, Service and Owners manuals
Old Jan 6, 2015 | 11:46 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Best way to figure this out..
Willcox
Old Jan 6, 2015 | 11:51 PM
R6n350GT's Avatar
R6n350GT
Willcox
Horn relay works, wire to horn works, just steering wheel horn to relay i dont know how to test.. ill look at this pic and try to figure it out. Thanks
Also u get my email re new parts to add to my order?
Old Jan 7, 2015 | 01:38 AM
R6n350GT's Avatar
R6n350GT
So turns out im missing this
Horn Contact Spring Kit. 67-82 $6.41
Part Number: 47410B-30016
Part Year: 1967-1982
And also the Retainer #37736 stopping the spring from making constant contact with the horn...
Old Jan 7, 2015 | 03:50 AM
R6n350GT's Avatar
R6n350GT
and missing
Horn Contact Plastic Retainer 5 Fingers 70-89 $10.00
Part Number: 350136
Part Year: 1970-1989
But i cant find where to buy the 419454 part "lower retainer" that goes into the steering spindle as per this diagram
and
Reading through this it doesnt even have one
http://willcoxcorvette.com/instructi...ed_updated.pdf
Unless its really the "Figure H2" ???
Old Jan 7, 2015 | 07:49 AM
R6n350GT's Avatar
R6n350GT
never mind its here but still not 100% where it goes
http://www.zip-corvette.com/catalog/...-nut-retainer/
Old Jan 7, 2015 | 12:48 PM
0Willcox Corvette
Former Vendor
The retainer below can be found at this link, http://willcoxcorvette.com/product_i...oducts_id=6951
On the later model cars, the upper steering column shaft had a groove in it and the retainer just snapped into it. A safety device to prevent the hub nut from coming off the car.
Mike has sent you an email about adding the parts to your order.
Willcox
Old Jan 7, 2015 | 03:27 PM
Alwyn678's Avatar
Alwyn678
I just fixed mine by removing the steering wheel and fixing the short.
Old Jan 7, 2015 | 04:57 PM
R6n350GT's Avatar
R6n350GT
Where was your short? mine was shorting due to the 5 finger plastic clip missing and constant horn blowing..
Old Jan 7, 2015 | 05:04 PM
R6n350GT's Avatar
R6n350GT
Willcox
Thanks, cant wait for all my parts
To horn doesn't work 1980 vette
