carter carb part
Old Jan 7, 2015 | 05:58 PM
brians76's Avatar
brians76
Default carter carb part
my '76 coupe has a carter afb 3345 competition carb and no choke housing. When I pump by hand and set the choke plate car starts and runs great, without choking it is hard starting but will start and run then after it is warmed. I want to install an electric choke but need a body for the housing and spring and electrics any ideas or should I just go with a manual choke which is possible to do
thanks in advance,
Brian
Old Jan 7, 2015 | 06:21 PM
DUB's Avatar
DUB
Check with EDELBROCK which I believe they make carbs like the Carter design and see if you can get an electric choke set-up for your design of carb....or...call Summit or Jegs and see what they say...and if all fails...do a manual choke.
DUB
