Valve Seals
Jun 6, 2013 | 09:52 AM
Valve Seals
I'm going to replace the valve seals on my 1976 L-82...is there anything else that is a "must-do" that should go along with this job (like springs)? Plan on getting the seals from GM, correct?
Jun 6, 2013 | 10:06 AM
St. Jude Donor '11 thru '25
I used Fel-Pro seals and have never had a problem.
Jun 6, 2013 | 10:30 AM
Royal Canadian Navy
You don't have to use GM seals. There are other types of seals that use various materials. However, depending what you choose may require machining of the valve stems.
Jun 6, 2013 | 10:36 AM
I don't want to get into any machining, just looking to replace the seals to stop the puff on start-up after long sits.
I would prefer to use GM seals, but I called the local dealer's parts deaprtment they tell me the seals are no longer available.
Jun 6, 2013 | 12:19 PM
I had the same problem with my '76 with a little blue smoke on start up. Fel-Pro seals, I believe I used the umbrella type, resolved the issue. My mileage was about 90K at the time.
Jun 6, 2013 | 12:32 PM
Thanks Jud, don't suppose you've got a part number that you recall?
Jun 6, 2013 | 12:53 PM
Quote:
Originally Posted by
Brcmpbl
This is more than likely what I used:
http://shop.advanceautoparts.com/web...alve+stem+seal
Fel-Pro is top of the line so you have nothing to worry about re quality. Jud
Jun 6, 2013 | 12:57 PM
Jun 6, 2013 | 03:32 PM
Thanks - I'll go after the Fel-Pro seals.
Jun 6, 2013 | 03:35 PM
You're welcome and good luck.
Jun 6, 2013 | 06:39 PM
Jud Chapin
Jun 6, 2013 | 08:48 PM
are u doing them with the heads on? if u do u need to put compressed air into the cyclinder so the valve don't drop when u release the spring
Jun 6, 2013 | 09:25 PM
I thought for sure I had a set and would have give sent them to you but I could not find them. They came with a gasket set I bought 5-6 years ago.
http://www.northernautoparts.com/Pro...tModelId=22596
Jun 6, 2013 | 09:42 PM
Yes, heads on. Compressed air will be used.
Thanks dunit, thought that counts!
